Error Message using DO WHILE Statement
Hi I am having problems with my code. It gives me the errors sketch_oct16c:12: error: expected unqualified-id before 'switch' sketch_oct16c:21: error: expected initializer before 'switchState' sketch_oct16c:22: error: expected unqualified-id before '{' token
This is the sketch:
#include
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int potpin = 0;  // analog pin used to connect the potentiometer
int val;    // variable to read the value from the analog pin
int switch = 9;
int switchState = 0;
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
switchState = digitalRead(switch);
{do
     // scale it to use it with the servo (value between 0 and 180)
  for(pos = 0; pos < 90; pos += val)  // goes from 0 degrees to 180 degrees
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 1, 30);    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(400);                       // waits 15ms for the servo to reach the position
    for(pos = 60; pos < 180; pos += val)  // goes from 0 degrees to 180 degrees
    delay(700);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-= val)     // goes from 180 degrees to 0 degrees
  delay(2000);
} while ( switch = 1);
/code]
In the sketch the pot acts as a speed controller for the servo sweep. I want to attach a switch (toggle switch) that puts on or off the continous sweep. Thanks
You haven't initialised the digital pins and the brace is in the wrong place in "void loop()"
switch is a key word, you can't use it for a variable name.
That is also going to give you some grief.
= assignment operator == comparison operator
The semicolon on the end of that statement makes the while loop an infinite loop, since the condition variable doesn't change in the empty body.
Thanks but i'm fairly new at this. Does anyone know what the final code will look like?
You all get started coding. I'll go find out what the requirements are.
That's what you're asking us to do. I'll wait.
The requirements are simple. The first part of the code works perfectly. It uses the pot as a speed controller while in a sweep function. I intend to add a toggle switch which basically turns the continous sweep on or off and this is where i have a problem.
How can it, when you can't even compile it?
This is the first part of the code. Like i explained, it works. I decided to add a start/stop switch as an added incentive. If anyone has an idea of how that can be done, that'll be helpful. Thanks / Sweep with speed control // by jedkoch http://jedkoch.com
include
Servo myservo; // create servo object to control a servo // a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position int potpin = 0; // analog pin used to connect the potentiometer int val; // variable to read the value from the analog pin
void setup() { myservo.attach(9); // attaches the servo on pin 9 to the servo object }
void loop() { // scale it to use it with the servo (value between 0 and 180)
for(pos = 0; pos < 90; pos += val) // goes from 0 degrees to 180 degrees { val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023) val = map(val, 0, 1023, 1, 30); // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' delay(400); // waits 15ms for the servo to reach the position }
for(pos = 60; pos < 180; pos += val) // goes from 0 degrees to 180 degrees { val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023) val = map(val, 0, 1023, 1, 30); // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' delay(700); // waits 15ms for the servo to reach the position }
for(pos = 180; pos>=1; pos-= val) // goes from 180 degrees to 0 degrees { val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023) val = map(val, 0, 1023, 1, 30); myservo.write(pos); // tell servo to go to position in variable 'pos' delay(400); // waits 15ms for the servo to reach the position }
delay(2000); }
Any code you want to add to the loop() function goes INSIDE the body of the loop function. Do you know what the start of the body of a function looks like? Here's a hint: {.
Where is the codeYOU added? BEFORE the {. It needs to be AFTER the {.
There are reserved words, like switch. You should use variable names that indicate the function of the value that the variable holds. Your variable switchState holds the state of the switch. That's a good name. Your variable switch holds a pin number. That's a lousy name. The name switchPin would be better, AND it would be legal.
Do/while statements are the worst possible statements, in my opinion. The check for whether the action should be performed is not tested until the end. So, you start the Arduino, and the servo waves around once, without you pressing the switch. Then, it stops until you press the switch. That is likely NOT what you want. So, don't use a do/while. Use a while statement, instead.
Thanks tried your suggestion with a while statement and changed it up a little bit but still getting little errors. This is the code:
#include
int switchPin = 9;
  pinMode (switchPin, INPUT);
void loop ( )
  //while button is high, run sweep
  while (digitalRead (switchState) == 1) {
    loop2();
void loop2()
}delay(2000);
} /code]
You are now trying to define a function, loop2(), inside another function, loop(). That is not allowed.
Thanks I saw my error and moved the loop and i don't get that error any more . I still get a couple of errors though on lines 51  and 52. it says:
sketch_oct17a:51: error: expected constructor, destructor, or type conversion before '(' token
sketch_oct17a:52: error: expected declaration before '}' token
i THINK I DIDNT PLACE the brackets in the correct position
[code
#include
int switchPin = 9;
}delay(2000);
void loop2 ( )
    loop();
Thanks I saw my error and moved the loop and i don’t get that error any more . I still get a couple of errors though on lines 51 and 52. it says:
sketch_oct17a:51: error: expected constructor, destructor, or type conversion before ‘(’ token
sketch_oct17a:52: error: expected declaration before ‘}’ token
the code i changed is just above
Put every { and } on separate lines. Use the tools/autoindent command to indent your code correctly. It will then be obvious that you have code outside of your functions.
Delete everything from 'void loop2 ( )' onwards since it is nonsense.
If i delete loop 2 how do i use the while statement to tell the arduino to continue running the sweep loop until the switch is turned off?
you cannot define a function inside the loop() function, but you can call it :
void loop ( )
    loop2();
void loop2()
should be :
     if(digitalRead(switchState) == 1)    // remember loop()  runs repeatedly, this test is done each time, so, no need of 'while'
           loop2();
           // other instructions if needed here
     else     //optional, you can add instructions which will be executed if switchState is not '1'
            // code executed if the previous digitalRead did not return a '1'
  // other instructions here
// here you define your loop2() function
void loop2()
    //instructions here
if you need to run loop2() as long as the switch is "1" , you can put the while statement in loop2()
void loop2()
    while(digitalRead(switchState==1))
           //code here
in this case, loop2() will be executed as soon as switchState is "1" and will run until it is not "1" but be aware that the other instructions in loop() won't be executed while switchState is "1"
Thanks it makes much more sense now.
One question though:
Can both loops be run together (lets say linked)
So the continous sweep with the pot as a speed control is loop one and the on off switch is loop two
So while loop one runs automatically, loop two starts or stops loop one depending on its state (high or low)
Would that make sense?
Loop one waves the sensor around in a continuous motion.
Loop two waves the sensor around in a continuous motion when the switch is pressed.
Exactly what does the switch do?
It looks to me like you want to do nothing when the switch is not pressed, and do something when the switch is pressed.
I think, aside from not being familiar with the syntax and structure of Arduino programs, that your biggest problem is that you can't even define the requirements for the program you want. Until you learn to define the requirements in an unambiguous way, you will continue to struggle.
