Error Message - Visual Basic
Hello,
I've made a program that controls my arduino with Visual Basic.
However currently when I start the program with the Arduino not connected and use a command I will get an error message that port com3 doesn't exist (serialport). Instead of crashing and showing that error I would like my program to create a popup and show a message a long the lines of "please connect your Arduino before continuing". I was wondering if any1 had any idea how to do this.
Thanks in advance :)
Hi
You can do a few things
First of all use Try/catch exception handling so that your program does not crash
Try
 myport = new SerialPort() ... bla blah
 myPort.open() ...
Catch (ex as Exception)
  Windows.Forms.MessageBox.Show("Unable to connect to arduino" + vbcrlf + ex.Message)
End Try
If you want to check if the port is available before hitting the error then...
There is a list (array of string port names) of serial ports in the System.IO namespace and also this article might be useful although I use .IO instead of My....
