Error message when trying to compile sketch (In file included from.....) (fatal error: functional: No such file or directory)
I am getting this error message when I try to complete my sketch. Can anyone help me?
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
In file included from C:\Users\maxdu\AppData\Local\Temp\Temp1_robojax_ESP-L298N-DC-Motor_library.zip\Robojax-L298N-DC-Motor\examples\ESP32_L298N_DC_motor_wifi\ESP32_L298N_DC_motor_wifi.ino:107:0:
C:\Users\maxdu\OneDrive\Documents\Arduino\libraries\src/WebServer.h:27:10: fatal error: functional: No such file or directory
#include
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
I’m guessing the unnamed file ‘__________’ doesn’t exist ?
Im not sure, because in my code and in the libraries folder the file is present. So im actually clueless about this error.
The filename should immediate;y follow the
#include __________ line.
Post your full sketch
It might be an error due to wrong preprocessing done by the IDE
Hi, @Maxdfalcon
Welcome to the forum.
It will show you how to post code in a scrolling frame.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Sure!
#include <Robojax_L298N_DC_motor.h>
// motor 1 settings
#define CHA 0
#define ENA 19 // this pin must be PWM enabled pin if Arduino board is used
#define IN1 18
#define IN2 5
// motor 2 settings
#define IN3 17
#define IN4 16
#define ENB 4// this pin must be PWM enabled pin if Arduino board is used
#define CHB 1
const int CCW = 2; // do not change
const int CW  = 1; // do not change
#define motor1 1 // do not change
#define motor2 2 // do not change
// for single motor
//Robojax_L298N_DC_motor motor(IN1, IN2, ENA, CHA, true);
// for two motors without debug information // Watch video instruciton for this line: https://youtu.be/2JTMqURJTwg
//Robojax_L298N_DC_motor motor(IN1, IN2, ENA, CHA, IN3, IN4, ENB, CHB);/
// fore two motors with debut information
Robojax_L298N_DC_motor motor(IN1, IN2, ENA, CHA, IN3, IN4, ENB, CHB, true);
int       motor1Direction = CW;//default direction of rotation
const int motor1changeStep = 10;// 10 is 10% every time button is pushed
int       motor1Speed = 40;// variable holding the light output vlaue (initial value) 40 means 40%
const int motor1MinimumSpeed=20;
const int motor1MaximumSpeed=100;
int       motor1StopState=HIGH;//Stope state of motor (HIGH means STOP) and LOW means Start
int       motor2Direction = CW;//default direction of rotation
const int motor2changeStep = 10;// 10 is 10% every time button is pushed
int       motor2Speed = 60;// variable holding the light output vlaue (initial value) 40 means 40%
const int motor2MinimumSpeed=20;
const int motor2MaximumSpeed=100;
int       motor2StopState=HIGH;//Stope state of motor (HIGH means STOP) and LOW means Start
#include "ESP32_L298N_DC_motor_wifi_page.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
const char *ssid = "Robojax";
const char *password = "xxx";
WebServer server(80);
const int led = 13;
void handleRoot() {
String HTML_page = motorControlHeader_1;
 HTML_page.concat(".bar1 {width: " + String(motor1Speed)  + "%;}
 //HTML_page.concat(motor1Speed);
 //HTML_page.concat("%;}");
 HTML_page.concat(".bar2 {width: " + String(motor2Speed) + "%;}
 HTML_page.concat(motorControlHeader_2);
 HTML_page.concat(motor1Control_p1);
 if(motor1Direction ==CW)
      if(motor1StopState ==HIGH)
        HTML_page.concat("<strong>Stopped - CW at ");
      }else{
        HTML_page.concat("<strong>Running - CW at ");
 }else{
        HTML_page.concat("<strong>Stopped - CCW at ");
      }else{
        HTML_page.concat("<strong>Running - CCW at ");
 HTML_page.concat(motor1Control_p2);
   HTML_page.concat("m1START\">START");
 }else{
   HTML_page.concat("m1STOP\">STOP");
 HTML_page.concat(motor1Control_p3);
///motor 2 begins
 HTML_page.concat(motor2Control_p1);
 if(motor2Direction ==CW)
      if(motor2StopState ==HIGH)
      }else{
 }else{
      }else{
 HTML_page.concat(motor2Speed);
 HTML_page.concat(motor2Control_p2);
   HTML_page.concat("m2START\">START");
 }else{
   HTML_page.concat("m2STOP\">STOP");
 HTML_page.concat(motor2Control_p3);
 HTML_page.concat("</body>
</html>");
  server.send(200, "text/html", HTML_page);
void handleNotFound() {
  digitalWrite(led, 1);
  String message = "File Not Found
  message += "URI: ";
  message += server.uri();
  message += "
Method: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "
Arguments: ";
  message += server.args();
  message += "
  for (uint8_t i = 0; i < server.args(); i++) {
    message += " " + server.argName(i) + ": " + server.arg(i) + "
  server.send(404, "text/plain", message);
  digitalWrite(led, 0);
void setup(void) {
  motor.begin();
  //L298N DC Motor by Robojax.com
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  if (MDNS.begin("robojaxESP32")) {
    Serial.print("MDNS responder started at http://");
    Serial.println("robojaxESP32");
  server.on("/", handleRoot);
  server.on("/speed", HTTP_GET, handleMotorSpeed);
  server.on("/direction", HTTP_GET, handleMotorDirection);
  server.on("/stop", HTTP_GET, handleMotorBrake);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("HTTP server started");
void loop(void) {
  server.handleClient();
    motor.brake(motor1);
  }else{
     motor.rotate(motor1, motor1Speed, motor1Direction);//run motor1 at motor1Speed% speed in motor1Direction
    motor.brake(motor2);
  }else{
     motor.rotate(motor2, motor2Speed, motor2Direction);//run motor2 at motor2Speed% speed in motor2Direction
  delay(100);
 * handleMotorSpeed()
 * Slows down or speeds up the motor
 * returns nothing
 * Written by Ahmad Shamshiri on Dec 27, 2019
 * www.Robojax.com
void handleMotorSpeed() {
  if(server.arg("do") == "m1slower" )
    motor1Speed -=motor1changeStep;
      if(motor1Speed < motor1MinimumSpeed)
        motor1Speed = motor1MinimumSpeed;
  }else if(server.arg("do") == "m1faster")
    motor1Speed +=motor1changeStep;
      if(motor1Speed > motor1MaximumSpeed)
        motor1Speed =motor1MaximumSpeed;
  }else if(server.arg("do") == "m2slower")
    motor2Speed -=motor2changeStep;
      if(motor2Speed < motor2MinimumSpeed)
        motor2Speed = motor2MinimumSpeed;
  }else if(server.arg("do") == "m2faster")
    motor2Speed +=motor2changeStep;
      if(motor2Speed > motor2MaximumSpeed)
        motor2Speed =motor2MaximumSpeed;
  }else{
    motor1Speed =0;
  handleRoot();
}//handleMotorSpeed() end
 * handleMotorDirection()
 * changes the direction of motor
 * returns nothing
 * www.Robojax.com
void handleMotorDirection() {
  if(server.arg("dir") == "m1CW")
    motor1Direction =CW;
  }else if(server.arg("dir") == "m1CCW")
    motor1Direction =CCW;
  }else if(server.arg("dir") == "m2CW")
    motor2Direction =CW;
  }else{
    motor2Direction =CCW;
  handleRoot();
 * handleMotorBrake()
 * applies brake to the motor
 * returns nothing
 * www.Robojax.com
void handleMotorBrake() {
  if(server.arg("do") == "m1START")
      motor1StopState=LOW;
  }else if(server.arg("do") == "m1STOP")
  }else if(server.arg("do") == "m2START")
      motor2StopState=LOW;
  }else{
  handleRoot();
what board are you really using?
I see you include
which are ESP related libraries but you are compiling for a UNO
sorry for the late response, I am using an esp32. I will try to change my board setting on the IDE. Thanks!
