Error message when uploading my sketch to a prototyping board!
Hello all, I managed to built a temperature sensor circuit using a DHT011 and it worked well while using the Arduino. However when I soldered it remotely on the prototyping board with all necessary components and connections, the sketch fails to upload and displays the error message below. Kindly help.
<Arduino: 1.8.8 (Windows 10), Board: “Arduino/Genuino Uno”
Warning: Board breadboard:avr:atmega328bb doesn’t define a ‘build.board’ preference. Auto-set to: AVR_ATMEGA328BB
WARNING: library DHTlib claims to run on (atmelavr) architecture(s) and may be incompatible with your current board which runs on (avr) architecture(s).
Sketch uses 5662 bytes (17%) of program storage space. Maximum is 32256 bytes.
Global variables use 285 bytes (13%) of dynamic memory, leaving 1763 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\POSIX\AppData\Local\Temp\arduino_build_608229/solderingAssg.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
“Show verbose output during compilation”
option enabled in File → Preferences.
It is not at all clear what you mean by "prototyping board".
If you have created a PCB with an Atmega 328 on it then the first step should be to see if you can get a simple BLINK program working.
How is your PC connected to the Atmega 328?
If you need more help then you need to post a schematic of your board so we can know what exactly you are trying to do. There are dozens, if not hundreds of things that can go wrong.
...R
