Sketch uses 5218 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 290 bytes (14%) of dynamic memory, leaving 1758 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't set com-state for "\\.\COM3"
Failed uploading: uploading error: exit status 1
this is the code:
//include the library code:
#include<NewPing.h>
#include<Servo.h>
#include<AFMotor.h>
#define RIGHT A2 // Right IR sensor connected to analog pin A2 of Arduino Uno:
#define LEFT A3 // Left IR sensor connected to analog pin A3 of Arduino Uno:
#define TRIGGER_PIN A1 // Trigger pin connected to analog pin A1 of Arduino Uno:
#define ECHO_PIN A0 // Echo pin connected to analog pin A0 of Arduino Uno:
#define MAX_DISTANCE 200 // Maximum ping distance:
unsigned int distance = 0; //Variable to store ultrasonic sensor distance:
unsigned int Right_Value = 0; //Variable to store Right IR sensor value:
unsigned int Left_Value = 0; //Variable to store Left IR sensor value:
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); //NewPing setup of pins and maximum distance:
//create motor objects
AF_DCMotor Motor1(1,MOTOR12_1KHZ);
AF_DCMotor Motor2(2,MOTOR12_1KHZ);
AF_DCMotor Motor3(3,MOTOR34_1KHZ);
AF_DCMotor Motor4(4,MOTOR34_1KHZ);
Servo myservo; //create servo object to control the servo:
int pos=0; //variable to store the servo position:
void setup() { // the setup function runs only once when power on the board or reset the board:
Serial.begin(9600); //initailize serial communication at 9600 bits per second:
myservo.attach(10); // servo attached to pin 10 of Arduino UNO
for(pos = 90; pos <= 180; pos += 1){ // goes from 90 degrees to 180 degrees:
myservo.write(pos); //tell servo to move according to the value of 'pos' variable:
delay(15); //wait 15ms for the servo to reach the position:
for(pos = 180; pos >= 0; pos-= 1) { // goes from 180 degrees to 0 degrees:
for(pos = 0; pos<=90; pos += 1) { //goes from 180 degrees to 0 degrees:
pinMode(RIGHT, INPUT); //set analog pin RIGHT as an input:
pinMode(LEFT, INPUT); //set analog pin RIGHT as an input:
// the lope function runs forever
delay(50); //wait 50ms between pings:
distance = sonar.ping_cm(); //send ping, get distance in cm and store it in 'distance' variable:
Serial.print("distance");
Serial.println(distance); // print the distance in serial monitor:
Right_Value = digitalRead(RIGHT); // read the value from Right IR sensor:
Left_Value = digitalRead(LEFT); // read the value from Left IR sensor:
Serial.print("RIGHT");
Serial.println(Right_Value); // print the right IR sensor value in serial monitor:
Serial.print("LEFT");
Serial.println(Left_Value); //print the left IR sensor value in serial monitor:
if((distance > 1) && (distance < 15)){ //check wheather the ultrasonic sensor's value stays between 1 to 15.
//If the condition is 'true' then the statement below will execute:
//Move Forward:
Motor1.setSpeed(130); //define motor1 speed:
Motor1.run(FORWARD); //rotate motor1 clockwise:
Motor2.setSpeed(130); //define motor2 speed:
Motor2.run(FORWARD); //rotate motor2 clockwise:
Motor3.setSpeed(130); //define motor3 speed:
Motor3.run(FORWARD); //rotate motor3 clockwise:
Motor4.setSpeed(130); //define motor4 speed:
Motor4.run(FORWARD); //rotate motor4 clockwise:
}else if((Right_Value==0) && (Left_Value==1)) { //If the condition is 'true' then the statement below will execute:
//Turn Left
Motor1.setSpeed(150); //define motor1 speed:
Motor1.run(FORWARD); //rotate motor1 cloclwise:
Motor2.setSpeed(150); //define motor2 speed:
Motor3.setSpeed(150); //define motor3 speed:
Motor3.run(BACKWARD); //rotate motor3 anticlockwise:
Motor4.setSpeed(150); //define motor4 speed:
Motor4.run(BACKWARD); //rotate motor4 anticlockwise:
delay(150);
}else if((Right_Value==1)&&(Left_Value==0)) { //If the condition is 'true' then the statement below will execute:
//Turn Right
Motor1.run(BACKWARD); //rotate motor1 anticlockwise:
Motor2.run(BACKWARD); //rotate motor2 anticlockwise:
delay(150);
}else if(distance > 15) { //If the condition is 'true' then the statement below will execute:
//Stop
Motor1.setSpeed(0); //define motor1 speed:
Motor1.run(RELEASE); //stop motor1:
Motor2.setSpeed(0); //define motor2 speed:
Motor2.run(RELEASE); //stop motor2:
Motor3.setSpeed(0); //define motor3 speed:
Motor3.run(RELEASE); //stop motor3:
Motor4.setSpeed(0); //define motor4 speed:
Motor4.run(RELEASE); //stop motor4:
im quite new to this stuff, so im not sure if this might be a possibilitie for the issue but i've downloaded the libraries for the servo, new ping, and Adafruit motor shield library as asked in the video. if anyone could help me out in what might be the issue i would be reallly thankfully
The IDE did not find the Arduino board connected to the COM3 port. Make sure it is there, connected with a data cable (some USB cables only connect power, not data). Reinitialize the Arduino IDE.
What kind of Arduino are you using? Is it original, or maybe chinese? Not that these are necessarily bad, but they may need a special driver installed in your computer.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
There were some previous reports of this "can't set com-state for ..." error occurring specifically when uploading to the boards that use the WCH CH340 USB chip (and apparently only specific batches of those chips). The problem only occurs when using the latest version of the CH340 driver.
The affected users have reported that doing a "roll back" to an older version of the driver was an effective workaround. You can give that a try.
I'll provide instructions:
Open this tutorial from SparkFun in your browser: https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all#drivers-if-you-need-them ⓘ We are using this tutorial as a source for an older version of the CH340 drivers. Generally I recommend only obtaining drivers from the manufacturer of the device, but WCH does not provide older versions of their drivers and SparkFun is trustworthy.
Click the "Windows (EXE)" link you see in red under the "Drivers (If You Need Them)" section of the tutorial.
Wait for the download to finish.
Run the downloaded CH341SER.EXE file.
A "User Account Control" dialog may now appear asking "Do you want to allow this app to make changes to your device?". Click the "Yes" button.
A "DriverSetup(X64)" dialog will appear. Click the "INSTALL" button in the dialog.
Wait for the driver installation to finish, as indicated by the appearance of a "Driver install success!" dialog.
Click the "OK" button in the "Driver install success!" dialog.
Click the X icon at the top right of the "DriverSetup(X64)" dialog to close it.
Close Arduino IDE if it is running.
Connect the Arduino board to your computer with a USB cable.
Select View > Devices by type from the Device Manager menus.
Open the "View" menu.
If there is a ✓ to the left of the "Show hidden devices" menu item, click on "Show hidden devices" to disable it.
Open the "Ports (COM & LPT)" section of the Device Manager tree.
You should see a port identified as "USB-SERIAL CH340 (COMn)" under the "Ports (COM & LPT)" section (where "COMn" is some serial port e.g., COM4). Right click on that item.
The "USB-SERIAL CH340 (COMn) Properties" dialog will open.
Select the "Drivers" tab of the "USB-SERIAL CH340 (COMn) Properties" dialog.
You will see a "Roll Back Driver" button in the dialog. If it is not clickable, perform the following instructions:
Click the "Update driver" button.
An "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog will open.
Click on "Search automatically for drivers" in the "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog.
You should now see the driver installation wizard update the driver. Wait for the update to finish, as indicated by the message "Windows has successfully updated your drivers" in the dialog.
It is possible you will instead see the message "The best drivers are already installed". If so, please stop following the instructions here and reply on the forum thread to let me know. I'll provide alternative instructions you can follow.
Click the "Close" button in the "Update Drivers Device - USB-SERIAL CH340 (COMn)" dialog.
Click the "Roll Back Driver" button in the "USB-SERIAL CH340 (COMn) Properties" dialog.
The "Driver Package rollback" dialog will open.
Click the radio button next to "My apps don't work with this driver" in the "Driver Package rollback" dialog .
Click the "Close" button in the "USB-SERIAL CH340 (COMn) Properties" dialog.
Now start Arduino IDE again and repeat whatever you were doing before when you encountered that error before. Hopefully this time you will not encounter that "can't set com-state" error during the sketch upload.
hi im having issues when uploading my code to my robot, im utilizing an arduino uno mini (wich i think might not be original,but im not sure) when uploading the code im getting the following error
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
this is the code:
#include<NewPing.h>
#include<Servo.h>
#include<AFMotor.h>
//Move Forward:
//Turn Left
delay(150);
//Turn Right
delay(150);
//Stop
if anyone could help with this error i would be really thankfully:)
in the arduino ide the only port im able to choose when i conect my arduino is COM3, on device manager it shows the usb cable name im using to conect the arduino to my laptop.
When using a Pro Mini, you need a serial-to-usb adapter; does your adapter use the CH340 chip?
There is (nowadays) a known issue with that CH340; advice is to roll back the driver. If you dig through these search results, you will find solutions; note that not everybody seems to have been successful in solving the problem.
I've moved your topic to a more suitable location on the forum.
I already warned you about cross-posting just yesterday. As promised, I have now given you a temporary account suspension due to your repeated cross-posting.
I hope that when you return to the forum you'll be more respectful of our community.
