Error message when uploading
Hi everyone . I bought an Arduino Uno 2 days ago and I never was able to upload anything to it .
I try to upload the sketch Blink , the rx led blinks 3 times , then I get an error ( I will post it below)
The arduino has the drivers , the COM port is the right one , the board is "Arduino/Genuino Uno" .
Here is the error :
Arduino: 1.6.11 (Windows 8.1), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\ACER\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8a
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Also , I'm using the ArduinoISP programmer .
Sorry I was unable to help more, and it's a shame you've received so little help on this forum. Here are a few more places you can go to seek help:
arduino.stackexchange.com/
forums.adafruit.com/viewforum.php?f=25&sid=699e86f2941fecf98a6a395b49b6859d
forum.sparkfun.com/viewforum.php?f=32&sid=f79496cf69ca87e5c07d2dbd791155f1
Luck to you,
Michael
I don't use the ISP programmer, but this is sometimes seen when the device driver is not installed. Look in the drivers directory of your IDE and trying running the appropriate installer.
The OP posted about this a few days ago but received no satisfaction, despite my best efforts. Strictly speaking, this a cross post, but I'm sympathetic since he's clearly desperate and the previous thread dried up. Here's the original with the history of what's been tried:
forum.arduino.cc/index.php?topic=422546.0
--Michael
