error message when verifying/ compiling a sketch programe
Hi all,
not the brightest person in programming but im having problems trying to run a sketch program and having no luck on my laptop running Vista home pro.  this is the the sketch  when i run it on my home computer it verify  on windows 7
  const int NumPortsToRead = 6;
  int AnalogResult[NumPortsToRead];
  volatile unsigned long TimeStamp = 0;
  volatile unsigned long time1 = 0;
  volatile unsigned long time2 = 0;
  volatile unsigned long Oldtime1 = 0;
  volatile unsigned long Oldtime2 = 0;
  volatile unsigned long TempTime1 = 0;
  volatile unsigned long TempTime2 = 0;
  String AllResult = "";
  int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  // Initialize serial communication
  // Ensure that Baud rate specified here matches that selected in SimpleDyno
  // Availailable Baud rates are:
  // 9600, 14400, 19200, 28800, 38400, 57600, 115200
  Serial.begin(38400);
  // Initialize interupts (Pin2 is interrupt 0 = RPM1, Pin3 in interrupt 1 = RPM2)
  attachInterrupt(0,channel1,FALLING);
  attachInterrupt(1,channel2,FALLING);
  AllResult = "";
  AllResult += micros();
  AllResult += ",";
  AllResult += TempTime1;
  AllResult += ",";
  AllResult += time1;
  AllResult += ",";
  AllResult += TempTime2;
  AllResult += ",";
  AllResult += time2;
  for (int Looper = 0; Looper < NumPortsToRead;Looper++){
    AnalogResult[Looper] = analogRead(Looper);
    AllResult += ",";
    AllResult += AnalogResult[Looper];
  Serial.println (AllResult);
  Serial.flush();
  delay(1);
//Interrupt routine for RPM1
void channel1(){
  TempTime1 = micros();
  time1 = TempTime1-Oldtime1;
  Oldtime1 = TempTime1;
//Interrupt routine for RPM2
void channel2(){
    TempTime2 = micros();
  time2 = TempTime2-Oldtime2;
  Oldtime2 = TempTime2;
this is the error when i verify it.
Arduino: 1.6.5 (Windows Vista), Board: “Arduino/Genuino Uno”
Build options changed, rebuilding all
avr-g++: error: CreateProcess: No such file or directory
Error compiling.
“Show verbose output during compilation”
enabled in File > Preferences.
Compiles OK for me. IDE 1.5.6-r2 Windows 7 Target board Uno
What are the corresponding details of your setup ?
im not sure but i did say it works on window 7’ but not on my windows vista on my laptop…its a program for a hall switch to run for a dyno rpm sensor.’
this is the other sketch its a weather station this doesn’t work on either.
#include <Wire.h>
#define BMP085_ADDRESS 0x77  // I2C address of BMP085
#include <DHT.h>
#include <Wire.h>
#define DHTPIN 7
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const unsigned char OSS = 0;  // Oversampling Setting
boolean page = false;
//Button
int switchPin = 13;   // momentary switch in 13, other side connected to ground
int Display = 0;
int prevstate = HIGH;
int currstate = LOW;
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
void setup(){
  Wire.begin();
  bmp085Calibration();
  dht.begin();
  lcd.begin(20,4);
  pinMode(switchPin, INPUT);  //Button
  digitalWrite(switchPin, HIGH); //Button
  lcd.backlight();
  delay(200);
  lcd.noBacklight();
  delay(200);
  lcd.backlight();
  lcd.setCursor(3,0); //Start at character 3 on line 0
  lcd.print("Mini Dyno 2000");
  lcd.setCursor(5,1);
  lcd.print("Powered by");
  lcd.setCursor(5,2);
  lcd.print("SimpleDyno");
  delay(2500);
  lcd.clear();
  float temperature = bmp085GetTemperature(bmp085ReadUT()); //MUST be called first Celcius converted to Fahrenheit
  float pressure = bmp085GetPressure(bmp085ReadUP());
  float atm = pressure / 101325; // "standard atmosphere"
  float alt = calcAltitude(pressure)*3.280; //Uncompensated caculation - in Meters to Feet
  float altm = calcAltitude(pressure);
  float ferinheight = (temperature* 9 +2)/5+32;
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float f = (t* 9 +2)/5+32;
  Serial.print("Temp BMP085: ");
  Serial.print(ferinheight); //display 2 decimal places
  Serial.println(" deg F");
  Serial.print("Pressure: ");
  Serial.print(pressure, 0); //whole number only.
  Serial.println(" Pa");
  Serial.print("Standard Atmosphere: ");
  Serial.println(atm, 4); //display 4 decimal places
  Serial.print("Altitude: ");
  Serial.print(alt, 2); //display 2 decimal places
  Serial.println(" Feet");
  Serial.print(altm, 2); //display 2 decimal places
  Serial.println(" Meters");
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.println(" %\t");
  Serial.print("Temp DHT11: ");
  Serial.print(f);
  Serial.println(" *F");
  Serial.println();//line break
  delay(1000); //wait a second and get values again.
  currstate = digitalRead(switchPin); //Button
  if (currstate != LOW){
    if (page == true){
      page = false;
  lcd.clear();
  lcd.setCursor(3,0);
  lcd.setCursor(3,1);
  lcd.print("Temp: ");
  lcd.print(ferinheight);
  lcd.print(" *F");
  lcd.setCursor(2,2);
  lcd.print("Humidity: ");
  lcd.print(h);
  lcd.print("%");
  lcd.setCursor(1,3);
  lcd.print("Altitude: ");
  lcd.print(alt);
  lcd.print("Ft");
  delay(2000);
  else if (currstate !=  HIGH){
    if (page == false){
      page = true;
  lcd.clear();
  lcd.setCursor(3,0);
  lcd.print(temperature);
  lcd.print(" *C");
  lcd.setCursor(1,1);
  lcd.print(altm);
  lcd.print(" M");
  lcd.setCursor(1,2);
  lcd.print("Standrd Atmo: ");
  lcd.print(atm);
  lcd.setCursor(0,3);
  lcd.print("Pressure:");
  lcd.print(pressure);
  lcd.print(" pa");
  delay(5000);
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
  ac1 = bmp085ReadInt(0xAA);
  ac2 = bmp085ReadInt(0xAC);
  ac3 = bmp085ReadInt(0xAE);
  ac4 = bmp085ReadInt(0xB0);
  ac5 = bmp085ReadInt(0xB2);
  ac6 = bmp085ReadInt(0xB4);
  b1 = bmp085ReadInt(0xB6);
  b2 = bmp085ReadInt(0xB8);
  mb = bmp085ReadInt(0xBA);
  mc = bmp085ReadInt(0xBC);
  md = bmp085ReadInt(0xBE);
// Calculate temperature in deg C
  float bmp085GetTemperature(unsigned int ut){
  long x1, x2;
  x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
  x2 = ((long)mc << 11)/(x1 + md);
  b5 = x1 + x2;
  float temp = ((b5 + 8)>>4);
  temp = temp /10;
  return temp;
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
  long bmp085GetPressure(unsigned long up){
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // Calculate B3
  x1 = (b2 * (b6 * b6)>>12)>>11;
  x2 = (ac2 * b6)>>11;
  x3 = x1 + x2;
  b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  // Calculate B4
  x1 = (ac3 * b6)>>13;
  x2 = (b1 * ((b6 * b6)>>12))>>16;
  x3 = ((x1 + x2) + 2)>>2;
  b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  if (b7 < 0x80000000)
    p = (b7<<1)/b4;
    p = (b7/b4)<<1;
  x1 = (p>>8) * (p>>8);
  x1 = (x1 * 3038)>>16;
  x2 = (-7357 * p)>>16;
  p += (x1 + x2 + 3791)>>4;
  long temp = p;
  return temp;
// Read 1 byte from the BMP085 at 'address'
  char bmp085Read(unsigned char address)
  unsigned char data;
  Wire.beginTransmission(BMP085_ADDRESS);
  Wire.write(address);
  Wire.endTransmission();
  Wire.requestFrom(BMP085_ADDRESS, 1);
  while(!Wire.available())
  return Wire.read();
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
  int bmp085ReadInt(unsigned char address)
  unsigned char msb, lsb;
  Wire.requestFrom(BMP085_ADDRESS, 2);
  while(Wire.available()<2)
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb<<8 | lsb;
// Read the uncompensated temperature value
  unsigned int bmp085ReadUT(){
  unsigned int ut;
  // Write 0x2E into Register 0xF4
  // This requests a temperature reading
  Wire.write(0xF4);
  Wire.write(0x2E);
  // Wait at least 4.5ms
  delay(5);
  // Read two bytes from registers 0xF6 and 0xF7
  ut = bmp085ReadInt(0xF6);
  return ut;
// Read the uncompensated pressure value
  unsigned long bmp085ReadUP(){
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  // Write 0x34+(OSS<<6) into register 0xF4
  // Request a pressure reading w/ oversampling setting
  Wire.write(0xF4);
  Wire.write(0x34 + (OSS<<6));
  // Wait for conversion, delay time dependent on OSS
  delay(2 + (3<<OSS));
  // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  msb = bmp085Read(0xF6);
  lsb = bmp085Read(0xF7);
  xlsb = bmp085Read(0xF8);
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  return up;
void writeRegister(int deviceAddress, byte address, byte val) {
  Wire.beginTransmission(deviceAddress); // start transmission to device
  Wire.write(address);       // send register address
  Wire.write(val);         // send value to write
  Wire.endTransmission();     // end transmission
  int readRegister(int deviceAddress, byte address){
  int v;
  Wire.write(address); // register to read
  Wire.requestFrom(deviceAddress, 1); // read a byte
  while(!Wire.available()) {
    // waiting
  v = Wire.read();
  return v;
  float calcAltitude(float pressure){
  float A = pressure/101325;
  float B = 1/5.25588;
  float C = pow(A,B);
  C = 1 - C;
  C = C /0.0000225577;
  return C;
the same error message
Error compiling.
im not sure but i did say it works on window 7’ but not on my windows vista on my laptop.
I missed that because you had included the information inside the code tags that you used for your program.
How about reinstalling the IDE on your laptop or ditching the abomination known as Vista ?
