Error message while compiling the code to send the captured image to android phn
#include <Adafruit_VC0706.h>
#include <MemoryCard.h>
#include <SdFat.h>
#include <JPEGCamera.h>
#include <NewSoftSerial.h>
#include <MeetAndroid.h>
//Create an instance of the camera
JPEGCamera camera;
MeetAndroid  meetAndroid;
//Create a character array to store the cameras response to commands
char response[32];
//Count is used to store the number of characters in the response string.
unsigned int count=0;
//Size will be set to the size of the jpeg image.
int size=0;
int c;
//This will keep track of the data address being read from the camera
int address=0;
//eof is a flag for the sketch to determine when the end of a file is detected
//while reading the file data from the camera.
int eof=0;
char *filePathImage = "/mduino/images/";
char val;  // variable to receive data from the serial port(bluetooth)
    // You always need to initialise the MemoryCard library
    Serial.println("Init MemoryCard...");
      // This demonstrates making a directory hierarchy
    Serial.println("Make directory...");
    MemoryCard.makeDir(filePathImage);
   // You can check for the existence of specific files/directories
   Serial.print(filePathImage);
   Serial.print(" does ");
   if (MemoryCard.exists(filePathImage)) {
     Serial.println("exist.");
     Serial.println("not exist.");
    //Setup the camera, serial port and memory card
    camera.begin();
    Serial.begin(57600);
  if(Serial.available())
    val = Serial.read();
    switch(val)
      case 'a':
            Serial.println("Take a picture!");
            MemoryCard.begin();
            //Reset the camera
            count=camera.reset(response);
            delay(3000);
            //Set Image size
            Serial.println("Set Image Size ");
            //camera.setImageSize160x120(response);
            //camera.setImageSize320x240(response);
           //count = camera.setImageSize640x480(response);
            Serial.write((const uint8_t*)response, count);
           Serial.print(" Image Size =");
            Serial.println(count);
            delay(200);
            //Reset the camera
            delay(3000);
            //Take a picture
            count=camera.takePicture(response);
            //Print the response to the 'TAKE_PICTURE' command.
            Serial.println("takePicture done! ");
            //Get the size of the picture
            count = camera.getSize(response, &size);
            //Print the size
            Serial.print("size=");
            Serial.print(size);
            //Create a file called 'test.txt' on the SD card.
            //NOTE: The memoryCard libary can only create text files.
            //The file has to be renamed to .jpg when copied to a computer.
            MemoryCard.open("/image2.txt", true);
            //Starting at address 0, keep reading data until we've read 'size' data.
            while(address < size)
                //Read the data starting at the current address.
                count=camera.readData(response, address);
                //Store all of the data that we read to the SD card
                for(int i=0; i<count; i++){
                    //Check the response for the eof indicator (0xFF, 0xD9). If we find it, set the eof flag
                    if((response[i] == (char)0xD9) && (response[i-1]==(char)0xFF))eof=1;
                    //Save the data to the SD card
                    MemoryCard.file.print(response[i], BYTE);
                  Serial.print(response[i]);
                    //If we found the eof character, get out of this loop and stop reading data
                    if(eof==1)break;
                //Increment the current address by the number of bytes we read
                address+=count;
                //Make sure we stop reading data if the eof flag is set.
                if(eof==1)break;
          MemoryCard.close();
          MemoryCard.open("/image2.txt");
//          // This approach is more compact
          while((c = MemoryCard.file.read()) >= 0)
             messageChar(1, c);
        //Close the file
               MemoryCard.close();
            count = camera.stopPictures(response);
                        Serial.println("Done!");
      case 'f':
          Serial.println("forward");
      default:
Error message i get,
sketch_aug31a.cpp: In function 'void loop()':
sketch_aug31a:126: error: initializer expression list treated as compound expression
Now im getting this error
sketch_aug31a:126: error: 'messageChar' was not declared in this scope
As in "I changed my code, but I don't want to post it again, and now..."?
Ashuk:
Ashuk:
Both error messages relate to messageChar(), which you call but don't declare or define anywhere in the code you have posted. What is this function?
