error message while using DS18B20 with Moteino
Hi everyone! I'm new to Arduino, and I've been having lots of trouble getting my code to upload properly.
Can anyone help me? Here is the error message I got on my most recent upload.
"Arduino: 1.6.5 (Mac OS X), Board: "Arduino Uno"
Sketch uses 7,062 bytes (21%) of program storage space. Maximum is 32,256 bytes.
Global variables use 355 bytes (17%) of dynamic memory, leaving 1,693 bytes for local variables. Maximum is 2,048 bytes.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'
WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'"
My code is attached. Thank you all!
temp_7.ino (928 Bytes)
You don't have a Programming problem, so you are in the wrong place.
Did you do what you were told?
If you had, you'd know that you need to post a shitload more information about what YOU have tried to do to solve the problem.
For such a tiny amount of code PLEASE post code, not attach.
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures(); // Send the command to get temperatures
  Serial.println("DONE");
  Serial.print("Temperature for the device 1 (index 0) is: ");
  Serial.println(sensors.getTempCByIndex(0));
PaulS, actually, on the arduino website, under "Programming Questions", "error messages" is listed. so, since I do have an error message, I am allowed to post here.
also, I am very new to Arduino and had posted in this forum hoping for constructive help. I understand now that I need to include more information, but at the time I posted, I obviously did not. I am learning, as did everyone at one point.
AWOL, thank you for the tip!
try other board besides arduino uno. or check what board you should select to work with moteino.
I don't know about your upload problem but the last warnings:
viviankim:
is due to a bug in the DallasTemperature library. I see it has been corrected on github (error introduced 15 July and corrected 17 July) but at least what I got downloaded mid August 2015 (in version 3.7.2) contains the bug.
You can get rid of the warnings by editing the library.properties found in ..../libraries/DallasTemperature/
Change
category=Sensor
to
category=Sensors
Regards
