Error Message with mismatched brackets
allup:119:3: error: a function-definition is not allowed here before ‘{’ token
exit status 1
I continue to get this error, I am very new to both C++ and Arduino, so please don’t destroy me. I am trying to save states to display to a 4 digit seven segment display. Everything that I have consulted has referenced mismatched brackets, but every single bracket that I have in this piece is matched, I went through and checked that everything had an accompanying bracket.
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(2, OUTPUT);
int number = 12;
void one()
digitalWrite(13, LOW);
digitalWrite(12, LOW);
digitalWrite(11, LOW);
digitalWrite(10, HIGH);
digitalWrite(9, LOW);
digitalWrite(8, LOW);
digitalWrite(7, LOW);
digitalWrite(6, HIGH);
void two()
digitalWrite(13, HIGH);
digitalWrite(12, HIGH);
digitalWrite(10, LOW);
digitalWrite(9, HIGH);
digitalWrite(8, HIGH);
void three()
void four()
digitalWrite(7, HIGH);
void five()
digitalWrite(6, LOW);
void six()
void seven()
void eight()
void nine()
void zero()
You can't define a function inside another function.
  int number = 12;
  void one()
Please remember to use code tags when posting code.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
first, follow above replies.
second, the compiler message says what you need: somewhere you have :
function1(void){
...//whatever
{function2(void){
} //for function2
} //for function1
this is not correct.
