Error Message within a void / for loop: was not declared in this scope
Hi I am currently trying to build code for a PCR machine, but having trouble with one portion of it. I wasn't able to attach the ENTIRE code because of limit on characters, but the part I am having trouble with is in the void runPCR() {
for (; cycles < NUM_CYCLES; cycles++) {
CURRENT_CYCLE = cycles;
It continues to tell me that 'cycles' was not declared in the scope...
Thank you ahead of time for any information.
/* Execute the desired number of PCR cycles.
void runPCR() {
    unsigned long cycleStartTime = millis();
    Serial.print("///CYCLE  ");
    Serial.print(cycles);
    time = millis();
    Serial.println("HEATING UP");
    CURRENT_PHASE = 'H';
    if (!heatUp(DENATURE_TEMP)) {
      // if unable to heat up, stop
      Serial.println("Unable to heat up... something is wrong :(");
      cycles = NUM_CYCLES;
    long dif = millis() - time;
    Serial.print("***TOTAL HEAT TIME ");
    Serial.println(dif);
    time = millis();
    Serial.println("DENATURATION");
    CURRENT_PHASE = 'D';
    if (cycles > 0) {
      holdConstantTemp(DENATURE_TIME, DENATURE_TEMP);
      // if this is the first cycles, hold denature temp for longer
      holdConstantTemp(INITIAL_DENATURE_TIME, DENATURE_TEMP);
    Serial.println("COOLING");
    time = millis();
    CURRENT_PHASE = 'C';
    coolDown((ANNEALING_TEMP));
    Serial.print("***TOTAL COOLING TIME ");
    Serial.println("ANNEALING");
    time = millis();
    CURRENT_PHASE = 'A';
    holdConstantTemp(ANNEALING_TIME, ANNEALING_TEMP);
    Serial.print("***TOTAL ANNEALING TIME ");
    time = millis();
    heatUp((EXTENSION_TEMP));
    Serial.print("***TOTAL HEAT UP TIME IS ");
    Serial.println("EXTENSION");
    time = millis();
    CURRENT_PHASE = 'E';
    if (cycles < (NUM_CYCLES - 1)) {
      holdConstantTemp(EXTENSION_TIME, EXTENSION_TEMP);
      // if this is the last cycle, hold extension temp for longer
      holdConstantTemp(FINAL_EXTENSION_TIME, EXTENSION_TEMP);
    Serial.print("***TOTAL EXTENSION TIME IS ");
    Serial.print("///TOTAL CYCLE TIME: ");
    Serial.println(millis() - cycleStartTime);
  Serial.println("DONE");
/* Set up all pins */
  pinMode(heatPin, OUTPUT);
  digitalWrite(heatPin, LOW);
  pinMode(fanPin, OUTPUT);
  digitalWrite(fanPin, LOW);
  // time out for 5 seconds.
  Serial.println("Starting in");
  for (int i = 5; i > 0; i--) {
    Serial.print(i);
    Serial.print("... ");
  runPCR();
int cycles = 0;
  //nothing
Well, where is it defined or declared?
and you declared 'cycles' where ? I found it between setup() & loop(), if you want variables to be global, declare them before any function.
Deva_Rishi:
Variables don't have to be declared before setup() and loop() to be global, although it is a good idea. They just need to be declared outside of any function. But they must be declared before they are used. That appears to be the problem here.
You are allowing for dif to be negative. How is THAT possible? Why do you need to allow for that possibility?
PaulS:
Only if elapsed time is about 25 days though...
