Error Message
Hi!
I'm working on a project with a friend installing ultrasonic sensors into a shoe while using vibrating motors to alert the wearer of an obstacle. I'm experiencing an error message and I cannot seem to correct it. Please forgive my ignorance.... Im a bit of a nube at this...
Here is my program:
//pin which triggers ultrasonic sound
const int pingPin = 17;
//pin which delivers time to receive echo using pulseIn()
int inPin = 19;
//range in cm which is considered safe to enter, anything
//coming within less than 31 cm triggers red LED
int safeZone = 7;
//LED pin numbers
int greenLed = 16;
int vibrator2=5;
int vibrator=11;
  // initialize serial communication
  //raw duration in milliseconds, cm is the
  //converted amount into a distance
  long duration, cm;
  //initializing the pin states
  pinMode(pingPin, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(vibrator2, OUTPUT);
  pinMode(vibrator,OUTPUT);
  //sending the signal, starting with LOW for a clean signal
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //setting up the input pin, and receiving the duration in
  //microseconds for the sound to bounce off the object infront
  pinMode(inPin, INPUT);
  duration = pulseIn(inPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  //printing the current readings to ther serial display
  Serial.print(cm);
  Serial.print("cm");
  //checking if anything is within the safezone, if not, keep
  //green LED on if safezone violated, activate red LED instead
  if (cm > safeZone)
    digitalWrite(greenLed, LOW);
    digitalWrite(vibrator2, LOW);
    digitalWrite(vibrator, LOW);
   digitalWrite(greenLed, HIGH);
    digitalWrite(vibrator2, HIGH);
    digitalWrite(vibrator, HIGH);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
The error message I'm getting is:
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop'
Thanks a lot for any help!
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Your whole sketch is enclosed in a comment, when it should be enclosed in code tags.
Your whole sketch is just a comment there is no code there /* starts a comment and */ ends it. Everything in between is ignored by the compiler!
Mark
