error message
I got the error message : avr-g++: error : missing file name after ‘-0’ exit status 1 compilation error
The sketch is as follows and I cannot locate the error as I’m a newbie. May you explain ?:
#include <SimpleSDAudio.h>
#include <BirdData.h>
const int SD_CARD_CS_PIN = 10;
const int PHOTOCELL_PIN = 0;
const unsigned int DATA_SIZE = 10;
const boolean DEBUG = false;
BirdData data[DATA_SIZE];
// Create static buffer
#define BIGBUFSIZE (2512) // bigger than 2512 is often only possible on Arduino megas!
uint8_t bigbuf[BIGBUFSIZE];
// helper function to determine free ram at runtime
int freeRam () {
extern int __heap_start, *__brkval;
int v;
return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void(* resetFunc) (void) = 0;//declare reset function at address 0
delay(2000);
Serial.print("Free Ram: "); Serial.flush();
Serial.println(freeRam()); Serial.flush();
// Setting the buffer manually for more flexibility
SdPlay.setWorkBuffer(bigbuf, BIGBUFSIZE);
Serial.print("\nInitializing SimpleSDAudio V" SSDA_VERSIONSTRING " …"); Serial.flush();
// If your SD card CS-Pin is not at Pin 4, enable and adapt the following line:
SdPlay.setSDD10Pin(SD_CARD_CS_PIN);
// Select between SSDA_MODE_FULLRATE or SSDA_MODE_HALFRATE (62.5kHz or 31.25kHz)
// and the output modes SSDA_MODE_MONO_BRIDGE, SSDA_MODE_MONO or SSDA_MODE_STEREO
if (!SdPlay.init(SSDA_MODE_HALFRATE | SSDA_MODE_MONO | SSDA_MODE_AUTOWORKER)) {
Serial.println(“initialization failed. Things to check:”); Serial.flush();
Serial.println("* is a card is inserted?"); Serial.flush();
Serial.println("* Is your wiring correct?"); Serial.flush();
Serial.println("* maybe you need to change the chipSelect pin to match your shield or module?"); Serial.flush();
Serial.print("Error code: "); Serial.flush();
Serial.println(SdPlay.getLastError()); Serial.flush();
delay(10000);
resetFunc();
// while(1);
Serial.println(“Wiring is correct and a card is present.”); Serial.flush();
randomSeed(analogRead(1));
Serial.println(“Initializing SD card…”); Serial.flush();
pinMode(10, OUTPUT);
loadSounds();
// Day(D) or Night(N)
char when = ‘D’; // ‘N’; // null;
// Determine the amount of light present to evaluate the day vs night settings.
// We also build in some tolerence if the photocell is missing or broken so the mode defaults to D
int pPin = analogRead(PHOTOCELL_PIN);
Serial.print("Photocell (0-1023): "); Serial.flush();
Serial.println(pPin); Serial.flush();
if(pPin < 200) {
when = ‘N’;
if(pPin > 30) {
playRandomWavFile(when);
// else - It is really dark out, so we won’t play any sounds right now.
// People want to sleep too. :slight_smile:
// random amount of wait time between calls
unsigned long waitTime = 10000;
if(‘D’ == when) {
// 10 - 30 minutes
waitTime = (random(600,1800) * 1000);
else if(‘N’ == when){
// 30 - 60 minutes
waitTime = (random(1800,3600) * 1000);
if(DEBUG) {
// override to 10 seconds
waitTime = 10000;
Serial.print("waitTime: "); Serial.flush();
Serial.println(waitTime); Serial.flush();
delay(waitTime);
void loadSounds() {
data[0].put(“1.wav”,5,5,7,4);
data[1].put(“2.wav”,7,5,24,2);
data[2].put(“3.wav”,8,5,22,2);
//data[3].put(“4.wav”,16,10,16,2); // 4.wav is broken, using 11 instead
data[3].put(“11.wav”,16,10,15,3);
data[4].put(“5.wav”,8,5,3,8);
data[5].put(“6.wav”,2,22,17,2);
data[6].put(“7.wav”,8,5,14,3);
data[7].put(“8.wav”,17,10,15,3);
//data[8].put(“9.wav”,7,5,3,7); // 9.wav is broken, using 5 instead
data[8].put(“5.wav”,7,5,3,8);
data[9].put(“10.wav”,4,18,28,2);
data[10].put(“11.wav”,18,10,15,3);
data[0] = &BirdData(“blackbird-splutter.wav”,5,5,30,2);
data[1] = &BirdData(“hawk1.wav”,7,5,30,2);
data[2] = &BirdData(“red-tailed-hawk-scream.wav”,8,5,30,2);
data[3] = &BirdData(“robin-distress.wav”,16,10,30,2);
data[4] = &BirdData(“blackbird-warning.wav”,8,5,30,2);
data[5] = &BirdData(“owl-agitated.wav”,2,22,30,2);
data[6] = &BirdData(“red-tailed-hawk2.wav”,8,5,30,2);
data[7] = &BirdData(“robin-warning.wav”,17,10,30,2);
data[8] = &BirdData(“falcon.wav”,7,5,30,2);
data[9] = &BirdData(“owl-contact.wav”,4,18,30,2);
data[10] = &BirdData(“robin-alarm.wav”,18,10,30,2);
void playRandomWavFile(char when) {
unsigned long rand = random(sumWeights(when));
unsigned long maxTimesStart = 16;
unsigned long runningWeights = 0;
for(unsigned int w = 0; w < DATA_SIZE; w++) {
runningWeights += data[w].getWeight(when);
if(rand < runningWeights) {
unsigned int maxTimes = (maxTimesStart+data[w].getMinTimes());
playSound(data[w].getWavFile(), data[w].getDuration(), random(data[w].getMinTimes(), maxTimes));
long sumWeights(char when) {
unsigned long weights = 0;
weights+=data[w].getWeight(when);
return weights;
void playSound(char* wavFile, int duration, long times){
Serial.print("Playing “);
Serial.print(wavFile);
Serial.print(” “);
Serial.print(times);
Serial.println(” times. "); Serial.flush();
Serial.print("duration: ");
Serial.println(duration); Serial.flush();
for(unsigned long i = 0; i < times; i++) {
Serial.println(i); Serial.flush();
// load the sound file
SdPlay.setFile(wavFile);
SdPlay.worker();
// play the sound file
SdPlay.play();
Serial.flush();
delay(duration * 1000);
SdPlay.stop();
int sdStatus = SdPlay.getLastError();
if(sdStatus != 0) {
Serial.print("SD Card Error Status: ");
Serial.println(sdStatus); Serial.flush();
resetFunc();
Kind regards.
(deleted)
