Error Message
Ive been making some code and im getting error messages like ‘\stray 342, \stray 200, \stray 230’. Here is the code so i hope you can see whats wrong? Thanks
#include <Keypad.h> //Include Keypad and servo library
#include <Servo.h>
Servo servoblue; //The servo is called „servoblue“ from now on
char* password = „123“; //We set the password. In this case „123“
int position = 0;
const byte ROWS = 4; //In this two lines we define how many rows and columns
const byte COLS = 3; //our keypad has
char keys[ROWS][COLS] = { //The characters on the keys are defined here
{‚#‘, ‚0‘, ‚*‘},
{‚9‘, ‚8‘, ‚7‘},
{‚6‘, ‚5‘, ‚4‘},
{‚3‘, ‚2‘, ‚1‘}
byte rowPins[ROWS] = {5, 6, 7, 8}; //The connection with the arduino is
byte colPins[COLS] = {2, 3, 4}; //listed here
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int redLED = 12; //The red LED is connected to pin 12
int greenLED = 13; //The green LED is connected to pin 13
pinMode(redLED, OUTPUT); //The LEDs are defined as Output
pinMode(greenLED, OUTPUT);
servoblue.attach(11); //The servo is connected to pin 11
setLocked(true);
char key = keypad.getKey();
if (key == ‚‘ || key == ‚#‘) If the lock is open it can be locked again by pushing „“ or „#“ on the //keypad
position = 0;
setLocked(true); //The command to close the lock after „*“ or „#“ is pushed
if (key == password[position])
position ++;
if (position == 3) //This part defines how many digits our code will have.In this case we have 3 digits //(123).
setLocked(false);
delay(100);
void setLocked(int locked)
if (locked) // If the lock is closed…
digitalWrite(redLED, HIGH); //…the red LED should light up…
digitalWrite(greenLED, LOW); //…the green LED not…
servoblue.write(90); //and the servo should turn to a 90 degree position.
else //if the lock is open…
digitalWrite(redLED, LOW); //…the red LED should be off…
digitalWrite(greenLED, HIGH); //…and the green LED should light up…
servoblue.write(0); //…and the servo should turn to a 0 degree position.
You have invalid Unicode characters in your sketch, probably copy and pasted from a web page.
Look for the fix encoding and reload option in the Arduino IDE menu.
