Hi there. I am hoping for somebody to help me.I have check the other forum with the same problem but i kinda having a hard time to understand it so i would be grateful for your help.And if you notice the other false i made please tell me
Thanks in advance!
this is the code:
#include <UTFT.h>
#include <URTouch.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
#include <DS3231.h>
#include <LiquidCrystal.h>
//==== Creating Objects
UTFT myGLCD(SSD1289, 38, 39, 40, 41); //Parameters should be adjusted to your Display/Schield model
URTouch myTouch( 6, 5, 4, 3, 2);
SoftwareSerial mp3Serial(11, 10); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
DS3231 rtc(SDA, SCL);
//==== Defining Fonts
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
extern unsigned int MusicPlayerButton[0x1040];
extern unsigned int AlarmButton[0x1040];
extern unsigned int ButtonPlay[0x1AE9];
extern unsigned int ButtonPause[0x1AE9];
extern unsigned int PreviousButton[0x9C4];
extern unsigned int NextButton[0x9C4];
extern unsigned int VolumeDown[0x170];
extern unsigned int VolumeUp[0x3B8];
int x, y; // Variables for the coordinates where the display has been pressed
char currentPage, playStatus;
int iV = 15;
int trackNum = 1;
int b = 16;
int aHours = 0;
int aMinutes = 0;
boolean alarmNotSet = true;
String alarmString = "";
float currentTemperature, temperature;
static word totalTime, elapsedTime, playback, minutes, seconds, lastSeconds, minutesR, secondsR;
String currentClock, currentHours, currentMinutes, currentSeconds, currentDate;
String timeString, hoursString, minutesString, secondsString, hoursS, minutesS, secondsS, dateS;
// Initiate display
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_MEDIUM);
// Initialize the rtc object
rtc.begin();
// Music
Serial.begin(9600); // set serial monitor baud rate to Arduino IDE
mp3Serial.begin(9600); // DFRobotDFPlayerMini set to 9600 baud (required)
myDFPlayer.setup(mp3Serial); // DFRobotDFPlayerMini myDFPlayer library which serial port to use.
delay(800); // allow time for DFRobotDFPlayerMini myDFPlayer cold boot; may adjust depending on flash storage size
drawHomeScreen(); // Draws the Home Screen
currentPage = '0'; // Indicates that we are at Home Screen
playStatus = '0';
myDFPlayer.volume(15);//Set volume value
delay(100);
currentTemperature = rtc.getTemp();
currentDate = rtc.getDateStr();
currentClock = rtc.getTimeStr();
timeString = rtc.getTimeStr();
currentHours = timeString.substring(0, 2);
currentMinutes = timeString.substring(3, 5);
currentSeconds = timeString.substring(6, 8);
// Homes Screen
if (currentPage == '0') {
// Checks for change of the clock
if ( currentClock != rtc.getTimeStr()) {
hoursS = timeString.substring(0, 2);
minutesS = timeString.substring(3, 5);
secondsS = timeString.substring(6, 8);
myGLCD.setFont(SevenSegNumFont);
myGLCD.setColor(0, 255, 0);
myGLCD.print(secondsS, 224, 50);
if ( currentMinutes != minutesS ) {
myGLCD.print(minutesS, 128, 50);
currentMinutes = minutesS;
if ( currentHours != hoursS ) {
myGLCD.print(hoursS, 32, 50);
currentHours = hoursS;
// Checks for change of the date
dateS = rtc.getDateStr();
delay(10);
if ( currentDate != dateS) {
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.setFont(BigFont); // Sets font to big
myGLCD.print(rtc.getDateStr(), 153, 7);
// Checks for change of the temperature
temperature = rtc.getTemp();
delay(10);
if ( currentTemperature != temperature ) {
myGLCD.printNumI(temperature, 39, 7);
currentTemperature = temperature;
delay(10);
// Checks whether the screen has been touched
if (myTouch.dataAvailable()) {
myTouch.read();
x = myTouch.getX(); // X coordinate where the screen has been pressed
y = myTouch.getY(); // Y coordinates where the screen has been pressed
// If we press the Music Player Button
if ((x >= 55) && (x <= 120) && (y >= 125) && (y <= 190)) {
drawFrame(87, 157, 33);
currentPage = '1';
myGLCD.clrScr();
delay(100);
drawMusicPlayerScreen();
delay(100);
// If we press the Alarm Button
if ((x >= 195) && (x <= 260) && (y >= 125) && (y <= 190)) {
drawFrame(227, 160, 29);
currentPage = '2';
myGLCD.clrScr();
// Music Player Screen
if (currentPage == '1') {
myTouch.read();
// If we press the Play Button
if ((x >= 116) && (x <= 204) && (y >= 77) && (y <= 165)) {
if (playStatus == '0') {
drawFrame(159, 121, 42);
drawPauseButton();
myDFPlayer.playTrackFromFolder(00, 001);
delay(100);
playStatus = '2';
return;
if (playStatus == '1') {
drawPauseButton();
myDFPlayer.play();
delay(100);
playStatus = '2';
return;
if (playStatus == '2') {
drawPlayButton();
myDFPlayer.pause();
delay(100);
playStatus = '1';
return;
// If we press the Previous Button
if ((x >= 45) && (x <= 95) && (y >= 97) && (y <= 147)) {
drawFrame(70, 121, 26);
myDFPlayer.previousTrack();
delay(100);
drawTrackBar();
// If we press the Next Button
if ((x >= 227) && (x <= 277) && (y >= 97) && (y <= 147)) {
drawFrame(252, 122, 26);
myDFPlayer.nextTrack();
delay(100);
drawTrackBar();
// If we press the VolumeDown Button
if ((x >= 35) && (x <= 75) && (y >= 165) && (y <= 209)) {
drawUnderline(45, 205, 65, 205);
if (iV >= 0 & iV <= 30) {
iV--;
drawVolume(iV);
myDFPlayer.decreaseVolume();
delay(100);
// If we press the VolumeUp Button
if ((x >= 230) && (x <= 280) && (y >= 165) && (y <= 209)) {
drawUnderline(235, 205, 275, 205);
iV++;
drawVolume(iV);
myDFPlayer.increaseVolume();
delay(100);
// If we press the MENU Button
if ((x >= 0) && (x <= 75) && (y >= 0) && (y <= 30)) {
myGLCD.clrScr();
currentPage = '0';
return;
// Updates the track bar
if (playStatus == '1' || playStatus == '2') {
trackPlayTime();
// Printing the clock in the upper right corner
printClock(187, 5);
// Alarm Clock Screen
if (currentPage == '2') {
myGLCD.print("MENU", 5, 5);
myGLCD.print("Set Alarm", CENTER, 20);
// Draws a colon between the hours and the minutes
myGLCD.fillCircle (112, 65, 4);
myGLCD.fillCircle (112, 85, 4);
myGLCD.printNumI(aHours, 32, 50, 2, '0');
myGLCD.printNumI(aMinutes, 128, 50, 2, '0');
myGLCD.drawRoundRect (42, 115, 82, 145);
myGLCD.drawRoundRect (138, 115, 178, 145);
myGLCD.print("H", 54, 122);
myGLCD.print("M", 150, 122);
myGLCD.drawRoundRect (215, 60, 303, 90);
myGLCD.print("SET", 236, 67);
myGLCD.drawRoundRect (215, 115, 303, 145);
myGLCD.print("CLEAR", 220, 122);
alarmNotSet = true;
while (alarmNotSet) {
myTouch.read();
//Set hours button
if ((x >= 42) && (x <= 82) && (y >= 115) && (y <= 145)) {
drawRectFrame(42, 115, 82, 145);
aHours++;
if (aHours >= 24) {
aHours = 0;
// Set minutes buttons
if ((x >= 138) && (x <= 178) && (y >= 115) && (y <= 145)) {
drawRectFrame(138, 115, 178, 145);
aMinutes++;
if (aMinutes >= 60) {
aMinutes = 0;
// Set alarm button
if ((x >= 215) && (x <= 303) && (y >= 60) && (y <= 80)) {
drawRectFrame(215, 60, 303, 90);
if (aHours < 10 && aMinutes < 10) {
alarmString = "0" + (String)aHours + ":" + "0" + (String)aMinutes + ":" + "00";
else if (aHours < 10 && aMinutes > 9) {
alarmString = "0" + (String)aHours + ":" + (String)aMinutes + ":" + "00";
else if (aHours > 9 && aMinutes < 10) {
alarmString = (String)aHours + ":" + "0" + (String)aMinutes + ":" + "00";
else {
alarmString = (String)aHours + ":" + (String)aMinutes + ":" + "00";
myGLCD.print("Alarm set for:", CENTER, 165);
myGLCD.print(alarmString, CENTER, 191);
// Clear alarm button
if ((x >= 215) && (x <= 303) && (y >= 115) && (y <= 145)) {
drawRectFrame(215, 115, 303, 145);
alarmString = "";
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(45, 165, 275, 210);
alarmNotSet = false;
currentPage = '0';
myGLCD.clrScr();
// Alarm activation
if (alarmNotSet == false) {
if (alarmString == rtc.getTimeStr()) {
myGLCD.clrScr();
myDFPlayer.setVolume(25);
myDFPlayer.playTrackByIndexNumber(1);
delay(100);
myGLCD.print("ALARM", CENTER, 90);
myGLCD.drawBitmap (127, 10, 65, 64, AlarmButton);
myGLCD.print(alarmString, CENTER, 114);
myGLCD.drawRoundRect (94, 146, 226, 170);
myGLCD.print("DISMISS", CENTER, 150);
boolean alarmOn = true;
while (alarmOn) {
myTouch.read();
// Stop alarm button
if ((x >= 94) && (x <= 226) && (y >= 146) && (y <= 170)) {
drawRectFrame(94, 146, 226, 170);
alarmOn = false;
alarmString = "";
myGLCD.clrScr();
myDFPlayer.stopPlayback();
delay(100);
currentPage = '0';
playStatus = '0';
myDFPlayer.setVolume(15);
drawHomeScreen();
void drawHomeScreen() {
myGLCD.setBackColor(0, 0, 0); // Sets the background color of the area where the text will be printed to black
myGLCD.print("T:", 7, 7);
myGLCD.printNumI(rtc.getTemp(), 39, 7);
myGLCD.print("C", 82, 7);
myGLCD.setFont(SmallFont);
myGLCD.print("o", 74, 5);
if (alarmString == "" ) {
myGLCD.print("n u h a f a", CENTER, 215);
else {
myGLCD.print("Alarm set for: ", 68, 215);
myGLCD.print(alarmString, 188, 215);
drawMusicPlayerButton();
drawAlarmButton();
drawHomeClock();
void drawMusicPlayerScreen() {
// Title
myGLCD.print("MENU", 5, 5); // Prints the string on the screen
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.drawLine(0, 26, 319, 26); // Draws the red line
myGLCD.setFont(SmallFont); // Sets font to big
myGLCD.print("n u h a f a", CENTER, 215); // Prints the string on the screen
// Volume Bar
myGLCD.fillRect (78, 184, 78 + 150, 184 + 8);
myGLCD.setColor(240, 196, 30);
myGLCD.fillRect (78, 184, 78 + 75, 184 + 8);
// Track Bar
myGLCD.fillRect (48, 50, 48 + 224, 50 + 8);
myGLCD.print("0:00", 8, 48);
myGLCD.print("-0:00", 276, 48);
drawPlayButton();
drawPauseButton();
drawPreviousButton();
drawNextButton();
drawVolumeDown();
drawVolumeUp();
void drawMusicPlayerButton() {
myGLCD.drawBitmap (55, 125, 65, 64, MusicPlayerButton);
void drawAlarmButton() {
myGLCD.drawBitmap (195, 125, 65, 64, AlarmButton);
void drawPlayButton() {
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPlay);
void drawPauseButton() {
myGLCD.drawBitmap (118, 79, 83, 83, ButtonPause);
void drawNextButton() {
myGLCD.drawBitmap (227, 97, 50, 50, NextButton);
void drawPreviousButton() {
myGLCD.drawBitmap (45, 97, 50, 50, PreviousButton);
void drawVolumeDown() {
myGLCD.drawBitmap (50, 177, 16, 23, VolumeDown);
void drawVolumeUp() {
myGLCD.drawBitmap (241, 175, 34, 28, VolumeUp);
// check for if Mp3 Player is stopped
bool checkFor_mp3IsStopped()
^~if (mp3Serial.available() > 0) {
if (myDFPlayer.getPlaybackStatus() == 0) {
return true;
if else return false;
// Highlights the button when pressed
void drawFrame(int x, int y, int r) {
myGLCD.drawCircle (x, y, r);
while (myTouch.dataAvailable())
myTouch.read();
void drawRectFrame(int x1, int y1, int x2, int y2) {
myGLCD.drawRoundRect (x1, y1, x2, y2);
myTouch.read();
void drawUnderline(int x1, int y1, int x2, int y2) {
myGLCD.drawLine (x1, y1, x2, y2);
myTouch.read();
// Sound bar
void drawVolume(int x) {
myGLCD.fillRect (78 + 5 * x, 184, 78 + 150, 184 + 8);
myGLCD.fillRect (78, 184, 78 + 5 * x, 184 + 8);
// Clears the track bar
void drawTrackBar() {
void trackPlayTime() {
totalTime = myDFPlayer.TrackPlaybackTime();
delay(10);
elapsedTime = myDFPlayer.ElapsedTrackPlaybackTime();
delay(10);
minutes = (int)elapsedTime / 60;
seconds = (((float)elapsedTime / 60) - minutes) * 60;
playback = totalTime - elapsedTime;
minutesR = (int)playback / 60;
secondsR = (((float)playback / 60) - minutesR) * 60;
myGLCD.printNumI(minutes, 8, 48);
myGLCD.print(":", 16, 48);
myGLCD.printNumI((int)seconds, 24, 48, 2, '0');
myGLCD.print("-", 276, 48);
myGLCD.printNumI(minutesR, 284, 48);
myGLCD.print(":", 292, 48);
myGLCD.printNumI((int)secondsR, 300, 48, 2, '0');
int trackBarX = map(elapsedTime, 0, totalTime, 0, 224);
myGLCD.fillRect (48, 50, 48 + trackBarX, 50 + 8);
if (totalTime == elapsedTime) {
myDFPlayer.next();
delay(30); //1000
void printClock(int x, int y) {
myGLCD.print(rtc.getTimeStr(), x, y);
void drawColon() {
myGLCD.fillCircle (208, 65, 4);
myGLCD.fillCircle (208, 85, 4);
void drawHomeClock() {
myGLCD.print(currentSeconds, 224, 50);
myGLCD.print(currentMinutes, 128, 50);
myGLCD.print(currentHours, 32, 50);
drawColon();
[/code]
and this is the error messages
Arduino: 1.8.15 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)
done:75:16: error: a function-definition is not allowed here before '{' token
done:481:38: error: a function-definition is not allowed here before '{' token
done:489:53: error: a function-definition is not allowed here before '{' token
done:497:53: error: a function-definition is not allowed here before '{' token
done:507:25: error: a function-definition is not allowed here before '{' token
done:515:22: error: a function-definition is not allowed here before '{' token
done:520:23: error: a function-definition is not allowed here before '{' token
done:555:32: error: a function-definition is not allowed here before '{' token
done:562:19: error: a function-definition is not allowed here before '{' token
void drawColon() {
done:573:22: error: a function-definition is not allowed here before '{' token
done:584:1: error: expected '}' at end of input
exit status 1
