I'm getting errors .
Please help
Mario
error:
Build options changed, rebuilding all
_1:3: error: uninitialized const 'servo_min' [-fpermissive]
_1:3: error: uninitialized const 'servo_max' [-fpermissive]
_1:4: error: expected initializer before 'p'
Code:
#include <Servo.h>
const float pi = 3.14159, theta_r = radians(48.0), theta_p = radians(23.2), theta_s[] = {-pi/3, 2pi/3, pi, 0, pi/3, -2pi/3},
RD = 2.395, PD = 3.3, L1 = 1.0, L2 = 4.72, z_home = 4.25, servo_min, servo_max, servo_mult
p[2][6] = {{PDcos(pi/6 + theta_p), PDcos(pi/6 - theta_p), PDcos(-(pi/2 - theta_p)), -PDcos(-(pi/2 - theta_p)), -PDcos(pi/6 - theta_p), -PDcos(pi/6 + theta_p)},
{PDsin(pi/6 + theta_p), PDsin(pi/6 - theta_p), PDsin(-(pi/2 - theta_p)), PDsin(-(pi/2 - theta_p)), PDsin(pi/6 - theta_p), PDsin(pi/6 + theta_p)}},
re[2][6] = {{RDcos(pi/6 + theta_r), RDcos(pi/6 - theta_r), RDcos(-(pi/2 - theta_r)), -RDcos(-(pi/2 - theta_r)), -RDcos(pi/6 - theta_r), -RDcos(pi/6 + theta_r)},
{RDsin(pi/6 + theta_r), RDsin(pi/6 - theta_r), RDsin(-(pi/2 - theta_r)), RDsin(-(pi/2 - theta_r)), RDsin(pi/6 - theta_r), RDsin(pi/6 + theta_r)}};
theta_r = angle between attachment points
theta_p = angle between rotation points
theta_s = orientation of the servos
RD = distance to end effector attachment points
PD = distance to servo rotation points
L1 = servo arm length
L2 = connecting arm length
z_home = default z height with servo arms horizontal
servo_min = lower limit for servo arm angle
servo_max = upper limit for servo arm angle
servo_mult = multiplier to convert to milliseconds
p = location of servo rotation points in base frame [x/y][1-6]
re = location of attachment points in end effector frame [x/y][1-6] /
const int servo_pin[] = {9,3, 5, 11, 6, 10}, servo_zero[6] = {1710, 1280, 1700, 1300, 1680, 1300}; /
servo_pin = servo pin assignments,
servo_zero = zero angles for each servo (horizontal)
Servo servo[6];
Servos 0, 2, 4: reversed (+ = down, - = up)
Servos 1, 3, 5: normal */
//Serial.begin(9600); for(int i = 0; i < 6; i++) {
(+ = up,
- = down)
servo.attach(servo_pin*);
servo.writeMicroseconds(servo_zero); }
delay(1000); }
static float pe[6] = {0,0,0,radians(0),radians(0),radians(0)}, theta_a[6], servo_pos[6],
_q[3][6], r[3][6], dl[3][6], dl2[6]; /
pe = location and orientation of end effector frame relative to the base frame [sway, surge, heave, pitch, roll, yaw)
theta_a = angle of the servo arm
servo_pos = value written to each servo
q = position of lower mounting point of connecting link [x,y,x][1-6] r = position of upper mounting point of connecting link
dl = difference between x,y,z coordinates of q and r
dl2 = distance between q and r
*/_
