Error messages please help :)
Hi I am making a roller coaster control panel using the Leonardo board. I have got an error but I was wondering if someone could check the code as well. The board is designed to work for a website called ride sims and each push button will send a key stroke to the PC. I have got the following error message;
:50: error: a function-definition is not allowed here before ‘{’ token
hopefully_final_panel_code:207: error: expected ‘}’ at end of input
exit status 1
Here is my script:
#include <Keyboard.h>
//Set Pin Values for buttons
int endofday;
int reset;
int switch1;
int switch2;
int switch3;
int switch4;
int sstop;
int preshow;
int estop;
int gates;
int restraints;
int tilt;
int stationselect;
int launch;
int dispatch;
// Initial variable states
int gateHX;
int restraintHX;
int selectorHX;
int estopHX;
int tiltHX;
int rcsenable;
int stationstopmode = 0; // S Stop is off
int disrdy = false; //dispatch ready is false
// Set buttons pinmodes
pinMode(endofday, INPUT_PULLUP);
pinMode(reset, INPUT_PULLUP);
pinMode(switch1, INPUT_PULLUP);
pinMode(switch2, INPUT_PULLUP);
pinMode(switch3, INPUT_PULLUP);
pinMode(switch4, INPUT_PULLUP);
pinMode(sstop, INPUT_PULLUP);
pinMode(preshow, INPUT_PULLUP);
pinMode(estop, INPUT_PULLUP);
pinMode(gates, INPUT_PULLUP);
pinMode(restraints, INPUT_PULLUP);
pinMode(tilt, INPUT_PULLUP);
pinMode(stationselect, INPUT_PULLUP);
pinMode(launch, INPUT_PULLUP);
pinMode(dispatch, INPUT_PULLUP);
// Set variables for button states
int endofdayPOS = digitalRead(endofday);
int resetPOS = digitalRead(reset);
int switch1POS = digitalRead(switch1);
int switch2POS = digitalRead(switch2);
int switch3POS = digitalRead(switch3);
int switch4POS = digitalRead(switch4);
int sstopPOS = digitalRead(sstop);
int preshowPOS = digitalRead(preshow);
int estopPOS = digitalRead(estop);
int gatePOS = digitalRead(gates);
int restraintPOS = digitalRead(restraints);
int tiltPOS = digitalRead(tilt);
int selectorPOS = digitalRead(stationselect);
int launchPOS = digitalRead(launch);
int dispatchPOS = digitalRead(dispatch);
// RCS MODE: Enabled
// sets the system to enabled RCS Mode anytime RCSenable variable is high and estop is high
if (restraintPOS == HIGH){
disrdy = false;}
else if (gatePOS == HIGH){
disrdy = false;}
disrdy = true;
// End Of Day function control
if (endofdayPOS == LOW){
Keyboard.end();} // Keyboard disabled
if (endofdayPOS == HIGH){
Keyboard.begin()} // Key strokes can be sent to PC
// Station Stop function control
if (sstopPOS == LOW){
stationstopmode = 1;} // Station Stop is ON
if (sstopPOS == HIGH){
stationstopmode = 0;} // Station stop is off
// Restraint function control
if (restraintHX != restraintPOS){
delay (100);}
if (restraintPOS == LOW){ // closed pos
Keyboard.press(KEY_DOWN_ARROW);
delay (100);
Keyboard.releaseAll();
restraintHX = restraintPOS;}
else{
Keyboard.press(KEY_UP_ARROW); // Open pos
delay (100);
// Gate function control
if (gateHX != gatePOS){
delay (100);}
if (gatePOS == LOW){ // If switch is in the closed position
Keyboard.press(KEY_LEFT_ARROW);
delay (100);
gateHX = gatePOS;}
else{
Keyboard.press(KEY_RIGHT_ARROW);
delay (100);
gateHX = gatePOS;}
// Selector function control
if (selectorHX != selectorPOS){
delay (100);}
if (selectorPOS == LOW){ // If switch is in the ‘one’ position
delay (100);
selectorHX = selectorPOS;}
else{
Keyboard.press(KEY_RIGHT_ARROW); // If switch is in the ‘two’ position
delay (100);
// Dispatch function control
if (dispatchPOS == LOW && stationstopmode == 0 && disrdy == true);{
Keyboard.press(’ ');
delay (100);
Keyboard.releaseAll();}
// Auto-stop when dispatch not ready
if (disrdy == false){
if (dispatchPOS == LOW)
Keyboard.press(‘s’);
delay (100);
estopHX = LOW;
rcsenable = LOW;}
// RCS Mode: E-Stop
if (estopPOS == LOW){
rcsenable = LOW;}
if (estopPOS == LOW && estopHX == HIGH){
estopHX = estopPOS;
delay (100);
// RCS Mode: Reset
if (resetPOS == LOW && estopPOS == HIGH && rcsenable == LOW){
rcsenable = HIGH;
estopHX = estopPOS;
Keyboard.press(‘r’);
delay (100);
//Preshow doors/start function
if (preshowPOS == LOW){
Keyboard.press(KEY_RETURN);
delay (100);
// Switch functions
if (switch1POS == LOW){
Keyboard.press(‘1’);
delay (100);
if (switch2POS == LOW){
Keyboard.press(‘2’);
delay (100);
if (switch3POS == LOW){
Keyboard.press(‘3’);
delay (100);
if (switch4POS == LOW){
Keyboard.press(‘4’);
delay (100);
// launch function
if (launchPOS == LOW && stationstopmode == 0){
Keyboard.press(‘l’);
delay (100);
// Tilt function
if (tiltPOS == HIGH && tiltHX == LOW && stationstopmode == 0){
Keyboard.release(KEY_RETURN);
tiltHX = tiltPOS;}
else{
Keyboard.press(KEY_RETURN);}
Your help would be greatly appreciated.
Thanks :slight_smile:
(deleted)
Please use code tags instead of quote; easier to read, easier to copy
If you auto-format your code in the IDE (T), you can easily see what is wrong. Functions should always start at the beginning of a line. If they don’t, you (usually) have a mismatch in ‘{’ and ‘}’.
loop() does not start at the beginning of a line, in this case because you did not close setup() with a ‘}’.
Thank You ! I have fixed it and no longer have any errors! Thanks! :)
