Hello
Just started using my Arduino Uno today, from a Mac (Os 10.8.3).
I started by uploading successfully the sketch example Blink.ino.
I then proceeded to write the sketch of project Nr 02 that came with my Arduino package :
int switchState = 0;
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(2,INPUT);
switchState = digitalRead(2);
if (switchState == LOW) {
digitalWrite(3, HIGH); // LED green
digitalWrite(4, LOW); // LED red
digitalWrite(5, LOW); // LED red
else { // appui sur le bouton
digitalWrite(3, LOW);
digitalWrite(5, HIGH);
delay(250); // wait for 1/4 sec
// faire clignoter les LEDs
digitalWrite(4, HIGH);
} // end of loop
I got the following series of messages related to the void setup and voidloop functions:
[12/30/2015, 7:43:15 PM] - Start Building
[12/30/2015, 7:43:15 PM] - CPP File Created [/var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp]
[12/30/2015, 7:43:15 PM] - projet-02.cpp compiled
[12/30/2015, 7:43:15 PM] - Command failed: /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp: In function 'void setup()': /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:37:6: error: redefinition of 'void setup()' void setup() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:24:6: error: 'void setup()' previously defined here void setup() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp: In function 'void loop()': /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:43:6: error: redefinition of 'void loop()' void loop() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:30:6: error: 'void loop()' previously defined here void loop() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp: At global scope: /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:64:10: error: expected constructor, destructor, or type conversion before '(' token pinMode(13, OUTPUT); ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451500995421/projet-02.cpp:65:1: error: expected declaration before '}' token } ^
Since then I cannot upload again the Blink.ino sketch, due to the same kind of errors :
[12/30/2015, 7:43:57 PM] - Start Building
[12/30/2015, 7:43:57 PM] - CPP File Created [/var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp]
[12/30/2015, 7:43:57 PM] - Blink.cpp compiled
[12/30/2015, 7:43:57 PM] - Command failed: /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp: In function 'void setup()': /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:37:6: error: redefinition of 'void setup()' void setup() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:24:6: error: 'void setup()' previously defined here void setup() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp: In function 'void loop()': /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:43:6: error: redefinition of 'void loop()' void loop() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:30:6: error: 'void loop()' previously defined here void loop() { ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp: At global scope: /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:64:10: error: expected constructor, destructor, or type conversion before '(' token pinMode(13, OUTPUT); ^ /var/folders/0r/r3r2qgh1547_d1wwzz8rdv0h0000gq/T//build1451501037375/Blink.cpp:65:1: error: expected declaration before '}' token } ^
What do I need to reset or correct to upload the sketches ?
Thanks
Regards
VPx
