I am a beginner level programmer and I was trying to upload my code when I got these error messages.
Command failed: /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp: In function 'void setup()': /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp:51:6: error: redefinition of 'void setup()' void setup(){ ^ /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp:18:6: error: 'void setup()' previously defined here void setup() { ^ /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp: In function 'void loop()': /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp:58:6: error: redefinition of 'void loop()' void loop(){ ^ /var/folders/f6/xgl4fkbs4sq34px5fkx9v68c0000gn/T//build1437767220962/Lamp.cpp:24:6: error: 'void loop()' previously defined here void loop() { ^
I looked back on my code and noticed that I expressed the function "void setup () {} and void loop() {}", so surely nothing could be wrong. Is this an Arduino IDE problem?
Here is the code from the Arduino projects book that I wanted to upload:
Paul S,
I believe something is wrong with the arduino ide. I am getting about 6 errors. I'm on a mac osx os. So if there is anything to changes in the arduino ide's preferences please let me know.
Nick Gammon,
I appreciate your time. I am running Arduino IDE version 0.0.2 Alpha on a MAC OSX operating system.
I have one other sketch that I have created on the IDE. I hope this info will help you.
FACEPALM Now I know why we are called noobs. I wonder why that version is on the Arduino site. Problem solved for now. Ill keep this forum posted in case it persists. Thankyou Nick Gammon. Because im new to the Arduino scene I didn't even realize what version of Arduino IDE I should use so I downloaded a terrible version FACEPALM.
I just started using it myself, being new to Arduno, why not check out the new tools? This seems to be a common problem when having multiple sketchs open simultaneously in ArduioStudio. Even closing all sketches, exiting the program and then coming back to the sketch does not seem to fix it.
Going to use the mature IDE now and wait for the next version of Studio.
It is simple - you have two *.ino files in your directory. If it tries to compile it takes both of them, just remove the second one or change its extension.
jviktes:
