Error messages
Can someone please explain what these error messages mean? I have tried Google and looking through the help files on this forum and others with no luck.
Adrian
Arduino: 1.6.4 (Windows 7), Board: "Arduino Uno"
Using library LedControl in folder: C:\Program Files (x86)\Arduino\libraries\LedControl1
Using library FontLEDClock in folder: C:\Program Files (x86)\Arduino\libraries\FontLEDClock (legacy)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library RTClib in folder: C:\Program Files (x86)\Arduino\libraries\RTClib (legacy)
Using library Button in folder: C:\Program Files (x86)\Arduino\libraries\Button (legacy)
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\LedControl1\src -IC:\Program Files (x86)\Arduino\libraries\FontLEDClock -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\RTClib -IC:\Program Files (x86)\Arduino\libraries\Button C:\Users\vk4kl\AppData\Local\Temp\build6407585483149142535.tmp\mini_clock1_0.cpp -o C:\Users\vk4kl\AppData\Local\Temp\build6407585483149142535.tmp\mini_clock1_0.cpp.o
In file included from mini_clock1_0.ino:13:0:
C:\Program Files (x86)\Arduino\libraries\FontLEDClock/FontLEDClock.h:4:35: error: variable 'myfont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 unsigned char PROGMEM myfont[80][5] = {
C:\Program Files (x86)\Arduino\libraries\FontLEDClock/FontLEDClock.h:94:39: error: variable 'mybigfont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 unsigned char PROGMEM mybigfont[10][20] = {
C:\Program Files (x86)\Arduino\libraries\FontLEDClock/FontLEDClock.h:108:38: error: variable 'mytinyfont' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 unsigned int PROGMEM mytinyfont[42][3] = {
mini_clock1_0.ino: In function 'void plot(byte, byte, byte)':
mini_clock1_0.ino:125:12: warning: comparison is always true due to limited range of data type [-Wtype-limits]
mini_clock1_0.ino: In function 'void puttinychar(byte, byte, char)':
mini_clock1_0.ino:217:16: warning: suggest parentheses around '&&' within '||' [-Wparentheses]
In file included from C:\Program Files (x86)\Arduino\libraries\LedControl1\src/LedControl.h:30:0,
                 from mini_clock1_0.ino:12:
mini_clock1_0.ino:243:44: warning: array subscript has type 'char' [-Wchar-subscripts]
mini_clock1_0.ino: In function 'void putnormalchar(byte, byte, char)':
mini_clock1_0.ino:291:40: warning: array subscript has type 'char' [-Wchar-subscripts]
mini_clock1_0.ino:291:45: warning: array subscript has type 'char' [-Wchar-subscripts]
mini_clock1_0.ino: In function 'void small_mode()':
mini_clock1_0.ino:401:15: warning: statement has no effect [-Wunused-value]
mini_clock1_0.ino:414:12: warning: unused variable 'x' [-Wunused-variable]
mini_clock1_0.ino:415:12: warning: unused variable 'y' [-Wunused-variable]
mini_clock1_0.ino: In function 'void basic_mode()':
mini_clock1_0.ino:436:8: warning: unused variable 'x' [-Wunused-variable]
mini_clock1_0.ino:436:11: warning: unused variable 'y' [-Wunused-variable]
mini_clock1_0.ino: In function 'void slideanim(byte, byte, byte, char, char)':
mini_clock1_0.ino:781:52: warning: array subscript has type 'char' [-Wchar-subscripts]
mini_clock1_0.ino:839:48: warning: array subscript has type 'char' [-Wchar-subscripts]
mini_clock1_0.ino: In function 'void switch_mode()':
mini_clock1_0.ino:1219:3: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mini_clock1_0.ino: In function 'void setup_menu()':
mini_clock1_0.ino:1302:45: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mini_clock1_0.ino:1304:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Error compiling.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
This way we can see what the errors are referring to.
Also do you have the libraries installed correctly?
Tom… :slight_smile:
TomGeorge:
Tom… :slight_smile:
Cant include the code due to exceeding the max allowable length.
Yes I have the libraries installed correctly. It appears there is a fault with the FontLEDClock.h file will have to look at the file some more
Adrian
You can attach it as a file. There is an Attachments option below the reply window.
I have had another FontLEDClock.h file and I found a problem with syntax and solved that but now the sketch wont compile even though no error messages appear.
Adrian
Am I the only one who can't see a sketch?
Here tis
Its not my sketch but I sent an email/reply to the authors site but no reply.
Adrian
mini_clock1_0.ino (43.3 KB)
I have just learnt a valuable lesson when compiling sketches with IDE. Get the right release.. I assumed (incorrectly obviously) that the latest release would be backward compatible. I have been trying to compile the clock sketch with release 1.6.5 when I should have been using 1.0.5. Next time I will read the instructions :(
Adrian
