Error messages
Hi all,
It may be a silly question for most . Being not so experienced in coding please let me know how to post the error messages in this forum that I get while trying to compile code . I use Arduino IDE 1.0.5 with Win 7 Starter pack. Thanks in advance for your time.
Nivar
Click the copy error message in the Arduino IDLE and then paste it as code when you write you question Hope this helps :)
If you are using Windows and if there is no “copy error” button, highlight the error and do ctrl-c to copy to clipboard. In the forum reply or post window, click on </> (code tags), put the cursor in the tag (<|/>), and shift-insert. That will put the error in code tags. Include the whole of the error text.
Hi All,
I was trying to compile the following code and got the error messages as attached at the end of this code. Please let me know what is wrong I am doing ?!! I am attaching the full code for better comprehension.
//302 lines (256 sloc) 5.92 KB
#include <Wire.h>
#include <SPI.h>
#include <Si570.h>
#include <si5351.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
/* #include <ssd1306_tiny.h>
ssd1306_tiny display; */
Si5351 si5351;
Si570 *si570=NULL;
#define SI570_I2C_ADDRESS 0x55
char printBuff[20];
#define LOG_AMP A3
//#define WB_POWER_CALIBERATION (-112)
#define WB_POWER_CALIBERATION (-92)
int  dbm_reading = 100;
int power_caliberation = WB_POWER_CALIBERATION;
char serial_in[32], c[30], b[30];
unsigned char serial_in_count = 0;
long frequency, fromFrequency=14150000, toFrequency=30000000, stepSize=100000;
#define TUNING  A2
int tune, previous = 500;
int count = 0;
int  i, pulse;
unsigned long baseTune = 14200000;
boolean sweepBusy = false;
/* display routines */
void printLine1(char *c){
  if (strcmp(c, printBuff)){
    lcd.setCursor(0, 0);
    lcd.print(c);
    strcpy(printBuff, c);
    count++;
void printLine2(char *c){
  lcd.setCursor(0, 1);
  lcd.print(c);
char *readNumber(char *p, long *number){
  *number = 0;
  sprintf(c, "#%s", p);
  while (*p){
    char c = *p;
    if ('0' <= c && c <= '9')
      *number = (*number * 10) + c - '0';
     p++;
  return p;
char *skipWhitespace(char *p){
  while (*p && (*p == ' ' || *p == ','))
    p++;
  return p;
/* command 'h' */
void sendStatus(){
  Serial.write("helo v1\n");
  sprintf(c, "from %ld\n", fromFrequency);
  Serial.write(c);
  sprintf(c, "to %ld\n", toFrequency);
  Serial.write(c);
  sprintf(c, "step %ld\n", stepSize);
  Serial.write(c);
void setFrequency(unsigned long f){
   if (si570 != NULL);
     si5351.set_freq(f,  0, SI5351_CLK1);
   frequency = f;
/* command 'g' to begin sweep
  each response begins with an 'r' followed by the frequency and the raw reading from ad8703 via the adc */
void doSweep(){
  unsigned long x;
  int a;
  sweepBusy = 1;
  Serial.write("begin\n");
  printLine1("Sweeping...");
  for (x = fromFrequency; x < toFrequency; x = x + stepSize){
    setFrequency(x);
    delay(10);
    a = analogRead(LOG_AMP) * 2 + (power_caliberation * 10);
    sprintf(c, "r%ld:%d\n", x, a);
    Serial.write(c);
  Serial.write("end\n");
//  si5351.set_freq(fromFrequency,  0, SI5351_CLK1);
  sweepBusy = 0;
/* command 'e' to end sweep */
void endSweep(){
  //to be done
void readDetector(){
  int i = analogRead(3);
  sprintf(c, "d%d\n", i);
  Serial.write(c);
void parseCommand(char *line){
  char *p = line;
  char command;
  while (*p){
    p = skipWhitespace(p);
    command = *p++;
    switch (command){
      case 'f' : //from - start frequency
        p = readNumber(p, &fromFrequency);
        setFrequency(fromFrequency);
      case 't':
        p = readNumber(p, &toFrequency);
      case 's':
        p = readNumber(p, &stepSize);
      case 'v':
        sendStatus();
      case 'g':
         sendStatus();
         doSweep();
      case 'r':
         readDetector();
      case 'o':
      case 'w':
      case 'n':
      case 'i': /* identifies itself */
        Serial.write("*iSweeperino 2.0\n");
  } /* end of the while loop */
void acceptCommand(){
  int inbyte = 0;
  inbyte = Serial.read();
  if (inbyte == '\n'){
    parseCommand(serial_in);
    return;
  if (serial_in_count < sizeof(serial_in)){
    serial_in[serial_in_count] = inbyte;
    serial_in_count++;
    serial_in[serial_in_count] = 0;
  lcd.begin(16, 2);
  printBuff[0] = 0;
  printLine1("Sweeperino v0.02");
  // Start serial and initialize the Si5351
  analogReference(DEFAULT);
  Serial.println("*Sweeperino v0.02\n");
  Serial.println("*Testing for Si570\n");
  si570 = new Si570(SI570_I2C_ADDRESS, 56320000);
  if (si570->status == SI570_ERROR) {
    printLine1("Si570 not found");
    Serial.println("*Si570 Not found\n");
    si570 = NULL;
    Serial.println("*Si5350 ON");
    printLine2("Si5351 ON");
    delay(10);
  else {
    Serial.println("*Si570 ON");
     printLine2("Si570 ON");
  setFrequency(14500000);
  previous  = analogRead(TUNING)/2;
void updateDisplay(){
  int j;
  sprintf(b, "%9ld", frequency);
  sprintf(c, "%.3s.%.3s.%3s ",  b, b+3, b+6);
  printLine1(c);
  sprintf(c,  "  %d.%d dbm  ", dbm_reading/10, abs(dbm_reading % 10));
  printLine2(c);
void doReading(){
  int new_reading = analogRead(LOG_AMP) * 2 + (power_caliberation * 10);
  if (abs(new_reading - dbm_reading) > 4){
    dbm_reading = new_reading;
    updateDisplay();
void doTuning(){
  tune = analogRead(TUNING);
  if (tune < 20){
    count++;
    if (count < 20){
      baseTune -= 1000;
      setFrequency(baseTune);
      updateDisplay();
      delay(100);
    else if (count < 60) {
      baseTune -= 10000;
      updateDisplay();
      delay(100);
    else {
      baseTune -= 500000;
      updateDisplay();
    return;
  if (tune > 1000){
    count++;
    if (count < 20){
      baseTune += 1000;
      setFrequency(baseTune + 100000);
      updateDisplay();
      delay(100);
      baseTune += 10000;
      updateDisplay();
      delay(100);
    else {
      baseTune += 500000;
      updateDisplay();
    return;
  count = 0;
  if (previous != tune){
    setFrequency(baseTune + (100L * (unsigned long)(tune-20)));
    updateDisplay();
    previous = tune;
void loop(){
  if (Serial.available()>0)
    acceptCommand();
  if (!sweepBusy){
    doReading();
    doTuning();
  delay(100);
And here is my error messages
sketch_apr20a.ino: In function ‘void setup()’:
sketch_apr20a:198: error: new initializer expression list treated as compound expression
sketch_apr20a:198: error: no matching function for call to ‘Si570::Si570(long int)’
C:\Program Files\Arduino\libraries\Si570/Si570.h:96: note: candidates are: Si570::Si570()
C:\Program Files\Arduino\libraries\Si570/Si570.h:96: note: Si570::Si570(const Si570&)
sketch_apr20a:199: error: ‘class Si570’ has no member named ‘status’
My special thanks to "groundfungus" for the prompt and bang on target reply. Also thanks to all other people for their time in reading my post and posting replies.
(Nivar)
