Error messages
My group and i have been having problems with our code and we cant figure out how to fix it. Could you help us? Thank you
This is the code
#include <IRremote.h>
#define code1 16712445 //code for forward button
#define code2 16769055 // code received from button LEFT
#define code3 16754775 // code received from button MIDDLE
#define code4 16748655 // code received from button RIGHT
int RECV_PIN = 11; //IR IS PLUGGED INTO PIN 11
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
pinMode(7,OUTPUT); //MAKE PIN 7 AN OUTPUT
pinMode(6,OUTPUT); //MAKE PIN 6 AN OUTPUT
pinMode(5,OUTPUT); //MAKE PIN 5 AN OUTPUT
pinMode(4,OUTPUT); //MAKE PIN 4 AN OUTPUT
if (irrecv.decode(&results)) {
unsigned int value = results.value;
switch(value) {
if (== (case code1):
digitalWrite(7,HIGH); //both motors are turned on to push the boat forward
digitalWrite(6,LOW);
digitalWrite(5,HIGH); //ON
digitalWrite(4,LOW);
else if (== (case code2):
digitalWrite(7,HIGH); //only the right motor is turned on to make the boat turn left
digitalWrite(5,LOW); //OFF
else if (== (case code4):
digitalWrite(7,LOW); //OFF
digitalWrite(5,HIGH); //only the left motor is turned on to make the boat turn right
else if (== (case code3):
digitalWrite(7,LOW); //all motors are turned off to make the boat stop moving
irrecv.resume(); // Receive the next value
And here are all the error messages
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Cuirithir\Desktop\full_sketch1\full_sketch1.ino: In function 'void loop()':
full_sketch1:38: error: expected primary-expression before '==' token
full_sketch1:38: error: expected primary-expression before 'case'
full_sketch1:38: error: expected ')' before 'case'
full_sketch1:40: error: expected ')' before ';' token
full_sketch1:48: error: expected '}' before 'else'
full_sketch1:48: error: expected primary-expression before '==' token
full_sketch1:48: error: expected primary-expression before 'case'
full_sketch1:48: error: expected ')' before 'case'
full_sketch1:50: error: expected ')' before ';' token
full_sketch1:56: error: break statement not within loop or switch
full_sketch1:57: error: 'else' without a previous 'if'
full_sketch1:57: error: expected primary-expression before '==' token
full_sketch1:57: error: expected primary-expression before 'case'
full_sketch1:57: error: expected ')' before 'case'
full_sketch1:59: error: expected ')' before ';' token
full_sketch1:65: error: break statement not within loop or switch
full_sketch1:66: error: 'else' without a previous 'if'
full_sketch1:66: error: expected primary-expression before '==' token
full_sketch1:66: error: expected primary-expression before 'case'
full_sketch1:66: error: expected ')' before 'case'
full_sketch1:68: error: expected ')' before ';' token
C:\Users\Cuirithir\Desktop\full_sketch1\full_sketch1.ino: At global scope:
full_sketch1:74: error: 'irrecv' does not name a type
full_sketch1:76: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
That's not a case - where have you seen that syntax?
Please use code tags when posting code.
switch(value) {
       case code1:
etc.
When you get the code to compile, and run it, you'll find that the value of code1 etc won't fit in sixteen bits.
Try unsigned long instead.
You can simplify the code a bit by using arrays. See if this makes sense.
#define ELEMENTS(x)  (sizeof(x) / sizeof(x[0]))
int pins[]   = {7, 6, 5, 4};
int states[] = {0, 0, 0, 0};
  for (int i = 0; i < ELEMENTS(pins); i++) {
    pinMode(pins[i], OUTPUT);
 Purpose: to set the pin states
 Paramter list:
  void
 Return value:
  void
 Caution: Assumes pins[] and states[] arrays exist globally
void WriteData()
    digitalWrite(pins[i], states[i]);
    unsigned int value = results.value;   // I'm assuming value is an int
    switch (value) {
      case 1:
        states[0] = 1;
        states[1] = 0;
        states[2] = 1;
        states[3] = 0;
        WriteData();
      case 2:
        states[0] = 1;
        states[1] = 0;
        states[2] = 0;
        states[3] = 0;
        WriteData();
      case 3:
        states[0] = 0;
        states[1] = 0;
        states[2] = 0;
        states[3] = 0;
        WriteData();
      case 4:
        states[0] = 0;
        states[1] = 0;
        states[2] = 1;
        states[3] = 0;
        WriteData();
      default:
        Serial.print("I shouldn't be here. value = ");
        Serial.println(value);
If it doesn't make sense, at least it compiles and might serve as a starting point.
EDIT: You could save a few bytes by removing each case call to WriteData() and then call it once before the irrecv.resume() call.
i uploaded the sketch to the arduino but the motors arent responding. Do you know what the problem might be?
Cuirithir:
Uploaded what sketch?
