error messages
Im getting these error messages
Arduino: 1.8.9 (Windows 8.1), Board: “Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
C:\Users\RENA M\AppData\Local\Microsoft\Windows\INetCache\IE\9XKHNQVY\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3.ino: In function ‘void setup()’:
ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3:78:27: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
WiFi.begin(ssid, password);
In file included from C:\Users\RENA M\AppData\Local\Microsoft\Windows\INetCache\IE\9XKHNQVY\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\WiFi\src/WiFi.h:79:9: error: initializing argument 1 of ‘int WiFiClass::begin(char*, const char*)’ [-fpermissive]
int begin(char* ssid, const char *passphrase);
C:\Users\RENA M\AppData\Local\Microsoft\Windows\INetCache\IE\9XKHNQVY\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3.ino: At global scope:
ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3:82:1: error: ‘ThingSpeak’ does not name a type
ThingSpeak.begin(client);
ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3:84:1: error: expected declaration before ‘}’ token
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
This is my code
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <ESP8266WiFi.h>;
#include <WiFiClient.h>;
#include <ThingSpeak.h>;
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//Define variables for the LCD
#define I2C_ADDR 0x27 //Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define TRIGGER 0
#define ECHO 2
// NodeMCU Pin d3 > TRIGGER | Pin d4 > ECHO
const char* ssid = “Eric”; //Your Network SSID
const char* password = “1234554321”; //Your Network Password
int val;
//int LDRpin = A0; //LDR Pin Connected at A0 Pin
WiFiClient client;
unsigned long myChannelNumber = 842412; //Your Channel Number (Without Brackets)
const char * myWriteAPIKey = “SPEC45UHZ1QY37D9”; //Your Write API Key
lcd.begin(16,2);
pinMode(TRIGGER, OUTPUT);
pinMode(ECHO, INPUT);
//pinMode(BUILTIN_LED, OUTPUT);
delay(10);
// Connect to WiFi network
WiFi.begin(ssid, password); //my error messages are for this line
long duration, distance;
digitalWrite(TRIGGER, LOW);
delayMicroseconds(2);
digitalWrite(TRIGGER, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO, HIGH);
distance= duration*0.034/2;
long level = 34 - distance;
Serial.print(distance);
Serial.println(“Centimeter:”);
Serial.print(level);
//val = analogRead(LDRpin); //Read Analog values and Store in val variable
//Serial.print(distance); //Print on Serial Monitor
lcd.setCursor(0,0); // Sets the location at which subsequent text written to the LCD will be displayed
lcd.print(“Dam Lev: “); // Prints string “Distance” on the LCD
lcd.print(level); // Prints the distance value from the sensor
lcd.print(” cm “);
delay(10);
lcd.setCursor(0,1);
lcd.print(“Danger Lev:”);
lcd.print(“15”);
lcd.print(” cm”);
delay(10);
ThingSpeak.writeField(myChannelNumber, 1,level, myWriteAPIKey); //Update in ThingSpeak
delay(100);
I don’t know what this error means. Can anyone help?
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
You're using the wrong library. You need to use the ESP8266WiFi library with your ESP8266, not the WiFi library. For some incomprehensible reason, you're attempting to use both in your sketch. The WiFi library is for the retired Arduino WiFi Shield, and I'm 100% certain you're not using one of those on your ESP8266.
You can find the ESP8266WiFi library's examples under File > Examples > ESP8266WiFi.
More information here:
https://arduino-esp8266.readthedocs.io/en/2.6.3/esp8266wifi/readme.html
I deleted it the <wifi.h> library
but im getting this error
(Thingspeak does not name a type)
In file included from C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
from C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
from C:\Users\RENA M\AppData\Local\Microsoft\Windows\INetCache\IE\9XKHNQVY\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3\ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3.ino:6:
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:262:36: error: expected ‘)’ before ‘*’ token
WiFiClientSecure(ClientContext *client, const X509List *chain, unsigned cert_issuer_key_type,
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:264:35: error: expected ‘)’ before ‘*’ token
WiFiClientSecure(ClientContext* client, const X509List *chain, const PrivateKey *sk,
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: ‘BearSSL::WiFiClientSecure::~WiFiClientSecure()’ marked override, but does not override
~WiFiClientSecure() override;
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:43:9: error: ‘int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)’ marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:48:12: error: ‘size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)’ marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:60:12: error: ‘size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)’ marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
Multiple libraries were found for “WiFiClient.h”
Used: C:\Program Files (x86)\Arduino\libraries\WiFi
Not used: C:\Users\RENA M\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WiFi
exit status 1
Please also use code tags, as explained at the link TomGeorge provided, when you post error output.
programmer8055:
But you’re still using the WiFi library:
programmer8055:
Delete all the lines of your sketch that come before this one:
I deleted the libraries above <esp8266wifi.h> and also the <wificlient.h>
but it shows that thingsspeak does not have a name .
Arduino: 1.8.9 (Windows 8.1), Board: "Generic ESP8266 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3:80:1: error: 'ThingSpeak' does not name a type
ultra_25_jul_cppy2__test3_checking_lc_and_ultra_working_eric3:82:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
That's a new problem, and you created a new topic to discuss it:
Let's confine the discussion of the ThingSpeak error to the other thread.
