//Terms of use
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
//THE SOFTWARE.
//Safety note
//Always remove the propellers and stay away from the motors unless you
//are 100% certain of what you are doing.
#include <Wire.h>
//Manual accelerometer calibration values for IMU angles:
int16_t manual_acc_pitch_cal_value = 0;
int16_t manual_acc_roll_cal_value = 0;
//Manual gyro calibration values.
//Set the use_manual_calibration variable to true to use the manual calibration variables.
uint8_t use_manual_calibration = false;
int16_t manual_gyro_pitch_cal_value = 0;
int16_t manual_gyro_roll_cal_value = 0;
int16_t manual_gyro_yaw_cal_value = 0;
HardWire HWire(2, I2C_FAST_MODE);
//Let's declare some variables so we can use them in the complete program.
//int16_t = signed 16 bit integer
//uint16_t = unsigned 16 bit integer
uint8_t disable_throttle, flip32;
uint32_t loop_timer;
float angle_roll_acc, angle_pitch_acc, angle_pitch, angle_roll;
float battery_voltage;
int16_t loop_counter;
uint8_t data, start, warning;
int16_t acc_axis[4], gyro_axis[4], temperature;
int32_t gyro_axis_cal[4], acc_axis_cal[4];
int32_t cal_int;
int32_t channel_1_start, channel_1;
int32_t channel_2_start, channel_2;
int32_t channel_3_start, channel_3;
int32_t channel_4_start, channel_4;
int32_t channel_5_start, channel_5;
int32_t channel_6_start, channel_6;
//The I2C address of the MPU-6050 is 0x68 in hexadecimal form.
uint8_t gyro_address = 0x68;
pinMode(4, INPUT_ANALOG);
//Port PB3 and PB4 are used as JTDO and JNTRST by default.
//The following function connects PB3 and PB4 to the alternate output function.
afio_cfg_debug_ports(AFIO_DEBUG_SW_ONLY); //Connects PB3 and PB4 to output function.
//On the Flip32 the LEDs are connected differently. A check is needed for controlling the LEDs.
pinMode(PB3, INPUT); //Set PB3 as input.
pinMode(PB4, INPUT); //Set PB4 as input.
if (digitalRead(PB3) || digitalRead(PB3))flip32 = 1; //Input PB3 and PB4 are high on the Flip32
else flip32 = 0;
pinMode(PB3, OUTPUT); //Set PB3 as output.
pinMode(PB4, OUTPUT); //Set PB4 as output.
green_led(LOW); //Set output PB3 low.
red_led(LOW); //Set output PB4 low.
Serial.begin(57600); //Set the serial output to 57600 kbps.
delay(100); //Give the serial port some time to start to prevent data loss.
timer_setup(); //Setup the timers for the receiver inputs and ESC's output.
delay(50); //Give the timers some time to start.
HWire.begin(); //Start the I2C as master
HWire.beginTransmission(gyro_address); //Start communication with the MPU-6050.
HWire.write(0x6B); //We want to write to the PWR_MGMT_1 register (6B hex).
HWire.write(0x00); //Set the register bits as 00000000 to activate the gyro.
HWire.endTransmission(); //End the transmission with the gyro.
HWire.write(0x1B); //We want to write to the GYRO_CONFIG register (1B hex).
HWire.write(0x08); //Set the register bits as 00001000 (500dps full scale).
HWire.write(0x1C); //We want to write to the ACCEL_CONFIG register (1A hex).
HWire.write(0x10); //Set the register bits as 00010000 (+/- 8g full scale range).
HWire.write(0x1A); //We want to write to the CONFIG register (1A hex).
HWire.write(0x03); //Set the register bits as 00000011 (Set Digital Low Pass Filter to ~43Hz).
print_intro(); //Print the intro on the serial monitor.
delay(10);
if (Serial.available() > 0) {
data = Serial.read(); //Read the incomming byte.
delay(100); //Wait for any other bytes to come in.
while (Serial.available() > 0)loop_counter = Serial.read(); //Empty the Serial buffer.
disable_throttle = 1; //Set the throttle to 1000us to disable the motors.
if (!disable_throttle) { //If the throttle is not disabled.
TIMER4_BASE->CCR1 = channel_3; //Set the throttle receiver input pulse to the ESC 1 output pulse.
TIMER4_BASE->CCR2 = channel_3; //Set the throttle receiver input pulse to the ESC 2 output pulse.
TIMER4_BASE->CCR3 = channel_3; //Set the throttle receiver input pulse to the ESC 3 output pulse.
TIMER4_BASE->CCR4 = channel_3; //Set the throttle receiver input pulse to the ESC 4 output pulse.
else { //If the throttle is disabled
TIMER4_BASE->CCR1 = 1000; //Set the ESC 1 output to 1000us to disable the motor.
TIMER4_BASE->CCR2 = 1000; //Set the ESC 2 output to 1000us to disable the motor.
TIMER4_BASE->CCR3 = 1000; //Set the ESC 3 output to 1000us to disable the motor.
TIMER4_BASE->CCR4 = 1000; //Set the ESC 4 output to 1000us to disable the motor.
if (data == 'a') {
Serial.println(F("Reading receiver input pulses."));
Serial.println(F("You can exit by sending a q (quit)."));
delay(2500);
reading_receiver_signals();
if (data == 'b') {
Serial.println(F("Starting the I2C scanner."));
i2c_scanner();
if (data == 'c') {
Serial.println(F("Reading raw gyro data."));
read_gyro_values();
if (data == 'd') {
Serial.println(F("Reading the raw accelerometer data."));
delay(2500);
read_gyro_values();
if (data == 'e') {
Serial.println(F("Reading the IMU angles."));
check_imu_angles();
if (data == 'f') {
Serial.println(F("Test the LEDs."));
test_leds();
if (data == 'g') {
Serial.println(F("Reading the battery voltage."));
check_battery_voltage();
if (data == 'h') {
Serial.println(F("Get manual gyro and accelerometer calibration values."));
manual_imu_calibration();
if (data == '1') {
Serial.println(F("Check motor 1 (front right, counter clockwise direction)."));
delay(2500);
check_motor_vibrations();
if (data == '2') {
Serial.println(F("Check motor 2 (rear right, clockwise direction)."));
delay(2500);
if (data == '3') {
Serial.println(F("Check motor 3 (rear left, counter clockwise direction)."));
delay(2500);
if (data == '4') {
Serial.println(F("Check motor 4 (front lefft, clockwise direction)."));
delay(2500);
if (data == '5') {
Serial.println(F("Check motor all motors."));
delay(2500);
void gyro_signalen(void) {
//Read the MPU-6050 data.
HWire.beginTransmission(gyro_address); //Start communication with the gyro.
HWire.write(0x3B); //Start reading @ register 43h and auto increment with every read.
HWire.endTransmission(); //End the transmission.
HWire.requestFrom(gyro_address, 14); //Request 14 bytes from the MPU 6050.
acc_axis[1] = HWire.read() << 8 | HWire.read(); //Add the low and high byte to the acc_x variable.
acc_axis[2] = HWire.read() << 8 | HWire.read(); //Add the low and high byte to the acc_y variable.
acc_axis[3] = HWire.read() << 8 | HWire.read(); //Add the low and high byte to the acc_z variable.
temperature = HWire.read() << 8 | HWire.read(); //Add the low and high byte to the temperature variable.
gyro_axis[1] = HWire.read() << 8 | HWire.read(); //Read high and low part of the angular data.
gyro_axis[2] = HWire.read() << 8 | HWire.read(); //Read high and low part of the angular data.
gyro_axis[3] = HWire.read() << 8 | HWire.read(); //Read high and low part of the angular data.
gyro_axis[2] *= -1; //Invert gyro so that nose up gives positive value.
gyro_axis[3] *= -1; //Invert gyro so that nose right gives positive value.
acc_axis[1] -= manual_acc_pitch_cal_value; //Subtact the manual accelerometer pitch calibration value.
acc_axis[2] -= manual_acc_roll_cal_value; //Subtact the manual accelerometer roll calibration value.
gyro_axis[1] -= manual_gyro_roll_cal_value; //Subtact the manual gyro roll calibration value.
gyro_axis[2] -= manual_gyro_pitch_cal_value; //Subtact the manual gyro pitch calibration value.
gyro_axis[3] -= manual_gyro_yaw_cal_value; //Subtact the manual gyro yaw calibration value.
void red_led(int8_t level) {
if (flip32)digitalWrite(PB4, !level);
else digitalWrite(PB4, level);
void green_led(int8_t level) {
if (flip32)digitalWrite(PB3, !level);
else digitalWrite(PB3, level);
please help me i cannot find a solution
