error:"'microsecondsToCentimeters' was not declared in this scope"
Hello, I get this error when I try to compile the code.
My idea was to build a Line-Follower and Obstacle Avoider at the same time.
I have to do this for a assignment at High-school and I can't solve this problem!
#include <QTRSensors.h>
#include <Ultrasonic.h>
#define KP 0.35
#define KD 7
#define M1_MAX_SPEED 200
#define M2_MAX_SPEED 200
#define M1_DEFAULT_SPEED 165
#define M2_DEFAULT_SPEED 165
#define MIDDLE_SENSOR A2, A3
#define NUM_SENSORS 6 // number of sensors used
#define TIMEOUT 2500 // waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
#define DEBUG 1 // set to 1 if serial debug output needed
#define rightMotor1 7
#define rightMotor2 8
#define rightMotorPWM 6
#define leftMotor1 10
#define leftMotor2 9
#define leftMotorPWM 5
#define motorPower 7
#define pino_trigger 13
#define pino_echo 12
QTRSensorsRC qtrrc((unsigned char[]) { A0, A1, A2, A3, A4, A5} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void manual_calibration() {
int i;
for (i = 0; i < 250; i++) // the calibration will take a few seconds
qtrrc.calibrate(QTR_EMITTERS_ON);
delay(100);
if (DEBUG) { // if true, generate sensor dats via serial output
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
pinMode(rightMotorPWM, OUTPUT);
pinMode(leftMotor1, OUTPUT);
pinMode(leftMotor2, OUTPUT);
pinMode(leftMotorPWM, OUTPUT);
pinMode(motorPower, OUTPUT);
manual_calibration();
int lastError = 0;
int last_proportional = 0;
int integral = 0;
long duration, cm;
pinMode(pino_trigger, OUTPUT);
digitalWrite(pino_trigger, LOW);
delayMicroseconds(2);
digitalWrite(pino_trigger, HIGH);
delayMicroseconds(10);
pinMode(pino_echo, INPUT);
duration = pulseIn(pino_echo, HIGH);
cm = microsecondsToCentimeters(duration);
if (cm < 8) {
else {
unsigned int sensors[6];
int position = qtrrc.readLine(sensors);
int error = position - 2500;
int motorSpeed = KP * error + KD * (error - lastError);
lastError = error;
int rightMotorSpeed = M2_DEFAULT_SPEED + motorSpeed;
int leftMotorSpeed = M1_DEFAULT_SPEED - motorSpeed;
if (rightMotorSpeed > M1_MAX_SPEED ) rightMotorSpeed = M1_MAX_SPEED; // limit top speed
if (leftMotorSpeed > M2_MAX_SPEED ) leftMotorSpeed = M2_MAX_SPEED; // limit top speed
if (rightMotorSpeed < 0) rightMotorSpeed = 0; // keep motor above 0
if (leftMotorSpeed < 0) leftMotorSpeed = 0; // keep motor speed above 0
digitalWrite(motorPower, HIGH);
digitalWrite(rightMotor1, HIGH);
digitalWrite(rightMotor2, LOW);
analogWrite(rightMotorPWM, rightMotorSpeed);
digitalWrite(leftMotor1, HIGH);
digitalWrite(leftMotor2, LOW);
analogWrite(leftMotorPWM, leftMotorSpeed);
The compiler isn't lying. Your sketch does not have a function named microsecondsToCentimeters()
Where did you get the code from ?
As posted it is not complete. Use Auto Format in the IDE and you will see that it does not end on the left margin as it should
Thank you for trying to use code tags when posting the code but you seem to have used Blockquote instead
Did you try a web-search for "microsecondsToCentimeters" ?
You might find code for this.
