error: missing terminating ' character
hi, learning to use it Arduino. my first interest is Infrared Sensors. i have PIR Sensor Module SE-10. i got code but uploading to I/O board getting message: error: missing terminating ' character.
how to make it work?
code what i have:
' // example for the PIR motion sensor SE-10
' int timer = 500;
' int alarmPin = 0;
' int alarmValue = 0;
' int ledPin = 11;
' void setup () {
' Serial.begin (9600);
' pinMode(ledPin, OUTPUT);
' pinMode(alarmPin, INPUT);
' delay (2000); // it takes the sensor 2 seconds to scan the area around it before it can
' detect infrared presence.
' void loop (){
' alarmValue = analogRead(alarmPin);
' if (alarmValue < 100){
' blinky(); // blinks when the motion has been detected, just for confirmation.
' delay(timer);
' Serial.println (alarmValue);
' delay (10);
' void blinky() {
' for(int i=0; i<3; i++) {
' digitalWrite(11,HIGH);
' delay(200);
' digitalWrite(11,LOW);
' delay(200);
For some reason you have a single-quote character at the beginning of every non-blank line in your sketch. They shouldn't be there. (none of them. There should be no single quotes in that entire sketch!) (Perhaps it was cut&pasted from some web page and internal formatting characters were accidentally copied along with the text itself.)
yes, thank you! it went well with uploading. cheers!
