Error msg in PROGMEM
Hi floks
im tring to store times in PROGMEM
but i got this Error : invalid types ‘char[int]’ for array subscript
i want to use variable (CityName) to use it when i change CityCode cityname will change
#include <avr/pgmspace.h> // Bur tamam
#include <EEPROM.h>
const long LONDON[][8] PROGMEM = {
{	1,	1,	539,	700,	1225,	325,	545,	701	},
{	2,	1,	540,	700,	1225,	325,	545,	701	},
{	3,	1,	540,	701,	1226,	326,	546,	702	},
{	4,	1,	540,	701,	1226,	327,	547,	702	},
{	5,	1,	541,	701,	1227,	327,	547,	703	},
{	6,	1,	541,	701,	1227,	328,	548,	704	},
{	7,	1,	541,	702,	1228,	329,	549,	704	},
{	8,	1,	541,	702,	1228,	329,	549,	705	},
{	9,	1,	542,	702,	1229,	330,	550,	706	},
{	10,	1,	542,	702,	1229,	331,	551,	706	},
const long NEWYOURK[][8] PROGMEM = {
{	1,	1,	539,	720,	1230,	325,	545,	708	},
{	2,	1,	540,	700,	1225,	345,	545,	701	},
{	10,	1,	542,	702,	1229,	339,	551,	706	},
int CityCode = EEPROM.read(7);
char CityName;
if (CityCode == 1)
CityName = 'LONDON';
if (CityCode == 2)
CityName = 'NEWYOURK';
    for (int r = 0; r <= 11; r++)
    if ((pgm_read_word( & CityName[ r ][ 0 ]) == day) && (pgm_read_word( & CityName[ r ][ 1 ]) == month)) //   <---- Error msg show Here.
   FA = pgm_read_word( & CityName[ r ][ 2 ] );
   SH = pgm_read_word( & CityName[ r ][ 3 ] );
   DH = pgm_read_word( & CityName[ r ][ 4 ] );
   AS = pgm_read_word( & CityName[ r ][ 5 ] );
   MA = pgm_read_word( & CityName[ r ][ 6 ] );
   ESH = pgm_read_word( & CityName[ r ][ 7 ] );
Show us a picture of your keyboard, with the ‘LONDON’ key highlighted.
That's not what I asked for :wink:
CityName is a single character.
It cannot have two dimensions, therefore it cannot have two subscripts.
It also can't hold the six characters LONDON.
Thank you for your explanation.
How i can solve this problem?
You could make your PROGMEM array three dimensional.
and it's NEWYORK
Please provide me a small code Example
const long cities[][iCantBeBotheredToCountEntries][8] PROGMEM
Same Problem :’(
#include <EEPROM.h>
const long LONDON[][1][8] PROGMEM = {
const long NEWYOURK[][1][8] PROGMEM = {
char CityName;
if (CityCode == 1)
if (CityCode == 2)
#include <EEPROM.h>
char CityName;
if (CityCode == 1)
if (CityCode == 2)
char CityName = 'NEWYOURK';
is not valid syntax for a string, it must be
char[] CityName = "NEWYOURK";
and it's New York...
Same Problem :cry:
but a different solution to the one outlined.
Re-read my earlier answer, and forget the idea that you can put six characters in a single "char" variable.
Just use the value you read from EEPROM as the first index.
aarg
char CityName = "NEWYORK";
still same problem
Alright, forget also the idea that you can subscript an array with anything other than an integer data type.
By the time the sketch is compiled the name of the array, either LONDON or NEWYORK no longer exists, so trying to refer to it by name (either as a C string or a C multicharacter variable) is utterly pointless.
Have another look at reply 8.
const long CITIES[2][10][8] PROGMEM = {
{	10,	1,	542,	702,	1229,	331,	551,	706	}},
{	10,
const long LONDON[][1][8] PROGMEM = { ...
I think you'll want to use pgm_read_dword() if your numbers are longs. Though I don't see why they're longs.
Looks to me like the "for" loop needs some work too.
Thanks for all
but that issue still no change
Now im using this code but get this Error msg :
CityNames:10: error: cannot convert ‘const long int ()[1][8]’ to 'const char const’ in initialization
const long NEWYUORK[][1][8] PROGMEM = {
const char* const CityNames[] PROGMEM = {LONDON, NEWYUORK}; //  <--- Error HIGHLIGHT
char buffer[30];
  while(!Serial);
  Serial.println("OK");
 int i = 1;
    strcpy_P(buffer, (char*)pgm_read_word(&(CityNames[i])));
    Serial.println(buffer);
Take a really close look at reply #13.
You've told the compiler there's a three dimensional array, where the second dimension is a single element, and you've initialised the array with two dimensions.
That's not at all confusing.
Now im using 3 dimintion but still get Error:
error: invalid types ‘const char[int]’ for array subscript
#include <EEPROM.h>
const long LONDON[10][10][8] PROGMEM = {
{	1,	2,	539,	700,	1225,	325,	545,	701	},
{	2,	3,	540,	700,	1225,	325,	545,	701	},
{	3,	4,	540,	701,	1226,	326,	546,	702	},
{	4,	5,	540,	701,	1226,	327,	547,	702	},
{	5,	6,	541,	701,	1227,	327,	547,	703	},
{	6,	7,	541,	701,	1227,	328,	548,	704	},
{	7,	8,	541,	702,	1228,	329,	549,	704	},
{	8,	10,	541,	702,	1228,	329,	549,	705	},
{	9,	11,	542,	702,	1229,	330,	550,	706	},
{	10,	12,	542,	702,	1229,	331,	551,	706	},
const long NEWYUORK[10][10][8] PROGMEM = {
{	1,	2,	555,	720,	1230,	335,	545,	708	},
{	2,	3,	540,	700,	1225,	345,	545,	701	},
{	8,	9,	541,	702,	1228,	329,	549,	705	},
{	9,	10,	542,	702,	1229,	330,	550,	706	},
{	10,	11,	542,	702,	1229,	339,	551,	706	},
const char* const CityNames[] PROGMEM = {LONDON, NEWYUORK}; //  <--- Error HIGHLIGHT <-------------------------
int CityCode = EEPROM.read(7); // CityCode as index
int FA;
int day = 1;
int month = 2;
    if ((pgm_read_word( & CityNames[CityCode][r][0]) == day) && (pgm_read_word( & CityNames[CityCode][r][1]) == month))
   FA = pgm_read_word( & CityNames[CityCode][r][2] );
You don’t have ten cities, you have two cities.
Uncompiled, untested, from your original post)
#include <EEPROM.h>
const long CITIES [2][10][8] PROGMEM = {
int CityCode;
int day, month, FA, SH,DH, AS, MA, ESH;
  char CityName = CityCode - 1;
  for (int r = 0; r < 10; r++)
    if ((pgm_read_word( &CITIES[CityName][r][ 0 ]) == day) && (pgm_read_word( & CITIES [CityName][ r ][ 1 ]) == month))
		   FA = pgm_read_word( & CITIES[CityName][ r ][ 2 ] );
		   SH = pgm_read_word( & CITIES[CityName][ r ][ 3 ] );
		   DH = pgm_read_word( & CITIES[CityName][ r ][ 4 ] );
		   AS = pgm_read_word( & CITIES[CityName][ r ][ 5 ] );
		   MA = pgm_read_word( & CITIES[CityName][ r ][ 6 ] );
		   ESH = pgm_read_word( & CITIES[CityName][ r ][ 7 ] );
