Error msg in ventilator code 'POSITION_PIN' was not declared in this scope
Here is the code:
Arduino Cloud (mod edit)
Here is the error message:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\DELL\Downloads\arduino codes\jeff_ebin_ventilator\jeff_ebin_ventilator\jeff_ebin_ventilator.ino: In function 'int get_position()':
jeff_ebin_ventilator:105:21: error: 'POSITION_PIN' was not declared in this scope
C:\Users\DELL\Downloads\arduino codes\jeff_ebin_ventilator\jeff_ebin_ventilator\jeff_ebin_ventilator.ino:105:21: note: suggested alternative: 'NOT_A_PIN'
exit status 1
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\lcd_test_code1: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\lcd_test_code1
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\sketch_test: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\sketch_test
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\sketch_test_2: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\sketch_test_2
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\stepper_test: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\stepper_test
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\stepper_test2: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\stepper_test2
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\stepper_working_code: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\stepper_working_code
option enabled in File -> Preferences.
There's a problem with the code you didn't post.
@arkodas
I edited your link for you.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Clearly "POSITION_PIN" was not declared in any manner so the program does not know what to do with it.
I presume that is something you added as I didn't see it in the original code on GITHUB ?
I am not so familiar with arduino forum and coding things. Can u please send me the link of the edited code? Thanks in advanced!!!
As you can see by a google search
There are multiple variations on this project on GITHUB.
I suggest you start with one of those and use the correct libraries as instructed in those repositories.
