Error msg using %
I'm trying to compute the bearing between 2 GPS locations. Anyhow, when I use the below code, I get an error:
float GPS_B_lat = 00.000000;     // latitude_destination at GPS B (test)
float GPS_B_long = -52.000000;  // longitude_destination at GPS B (test)
// angle off ot True North from GPS_A to GPS_B
float GPS_heading;
// Latitude conversion
int GPS_lat_integer = GPS.latitude/100; // get only integer part of lat
float GPS_lat_shifting = GPS.latitude - (GPS_lat_integer * 100);
float GPS_lat_decimal_conversion = (GPS_lat_shifting / 60);
float GPS_A_lat = GPS_lat_integer + GPS_lat_decimal_conversion;
// Longitude conversion
int GPS_long_integer = GPS.longitude/100; // get only integer part of long
float GPS_long_shifting = GPS.longitude - (GPS_long_integer * 100);
float GPS_long_decimal_conversion = (GPS_long_shifting / 60);
float GPS_A_long = (-1)*(GPS_long_integer + GPS_long_decimal_conversion);
GPS_heading = (180 / M_PI) * (atan2(sin(GPS_B_long - GPS_A_long)*cos(GPS_B_lat), cos(GPS_A_lat)*sin(GPS_B_lat) - sin(GPS_A_lat)*cos(GPS_B_lat)*cos(GPS_B_long - GPS_A_long)));
GPS_heading = (GPS_heading + 360) % 360;
The error says:
" invalid operands of type 'float' and 'int' to binary 'operator%' " " In function 'void GPS_output()': " " error: invalid operands of types 'float' and 'int' to binary 'operator% '
If were were to remove the last line, my code runs. It's something about using the " % " in there.
Any ideas?
Both operands of % must be integer. You could use:
((int)GPS_heading + 360) % 360;
Pete
For accuracy, you can do something like this instead:
GPS_heading = fmod( GPS_heading, 360.0 );
if ( GPS_heading < 0 )
    GPS_heading += 360.0;
