Error msgs with Tutorial Bluetooth Project
Hi Everyone,
I hope this finds everyone well.
Ive been trying to create this tutorial project...
http://playground.arduino.cc/Learning/Tutorial01
I have followed each of the steps and uploaded the wiring code successfully.
I have then created the a second code file for the processing code as shown in the lower sections of the guide.
The issue I have is that when I compile the code, it returns multiple error messages:-
Bluetooth_Control_Code:2: error: 'import' does not name a type
Bluetooth_Control_Code:5: error: 'Serial' does not name a type
Bluetooth_Control_Code:9: error: 'color' does not name a type
Bluetooth_Control_Code:10: error: 'RectButton' does not name a type
Bluetooth_Control_Code.ino: In function 'void setup()':
Bluetooth_Control_Code:14: error: 'size' was not declared in this scope
Bluetooth_Control_Code:15: error: 'color' was not declared in this scope
Bluetooth_Control_Code:15: error: expected ;' before 'baseColor' Bluetooth_Control_Code:16: error: 'currentcolor' was not declared in this scope Bluetooth_Control_Code:16: error: 'baseColor' was not declared in this scope Bluetooth_Control_Code:23: error: 'class HardwareSerial' has no member named 'list' Bluetooth_Control_Code:23: error: 'println' was not declared in this scope Bluetooth_Control_Code:29: error: 'port' was not declared in this scope Bluetooth_Control_Code:29: error: expected type-specifier before 'Serial' Bluetooth_Control_Code:29: error: expected ;' before 'Serial'
Bluetooth_Control_Code:36: error: expected ;' before 'buttoncolor' Bluetooth_Control_Code:37: error: expected ;' before 'highlight'
Bluetooth_Control_Code:38: error: 'rect1' was not declared in this scope
Bluetooth_Control_Code:38: error: expected type-specifier before 'RectButton'
Bluetooth_Control_Code:38: error: expected ;' before 'RectButton' Bluetooth_Control_Code:45: error: 'buttoncolor' was not declared in this scope Bluetooth_Control_Code:46: error: 'highlight' was not declared in this scope Bluetooth_Control_Code:47: error: 'rect2' was not declared in this scope Bluetooth_Control_Code:47: error: expected type-specifier before 'RectButton' Bluetooth_Control_Code:47: error: expected ;' before 'RectButton'
Bluetooth_Control_Code.ino: In function 'void draw()':
Bluetooth_Control_Code:54: error: 'currentcolor' was not declared in this scope
Bluetooth_Control_Code:54: error: 'background' was not declared in this scope
Bluetooth_Control_Code:55: error: 'stroke' was not declared in this scope
Bluetooth_Control_Code:56: error: 'mouseX' was not declared in this scope
Bluetooth_Control_Code:56: error: 'mouseY' was not declared in this scope
Bluetooth_Control_Code:57: error: 'rect1' was not declared in this scope
Bluetooth_Control_Code:58: error: 'rect2' was not declared in this scope
Bluetooth_Control_Code.ino: In function 'void update(int, int)':
Bluetooth_Control_Code:68: error: 'rect1' was not declared in this scope
Bluetooth_Control_Code:69: error: 'rect2' was not declared in this scope
Bluetooth_Control_Code:77: error: 'mousePressed' was not declared in this scope
Bluetooth_Control_Code:78: error: 'rect1' was not declared in this scope
Bluetooth_Control_Code:79: error: 'currentcolor' was not declared in this scope
Bluetooth_Control_Code:80: error: 'port' was not declared in this scope
Bluetooth_Control_Code:81: error: 'rect2' was not declared in this scope
Bluetooth_Control_Code:82: error: 'currentcolor' was not declared in this scope
Bluetooth_Control_Code:83: error: 'port' was not declared in this scope
Bluetooth_Control_Code.ino: At global scope:
Bluetooth_Control_Code:94: error: 'color' does not name a type
Bluetooth_Control_Code:95: error: 'color' does not name a type
Bluetooth_Control_Code:96: error: ISO C++ forbids initialization of member 'over'
Bluetooth_Control_Code:96: error: making 'over' static
Bluetooth_Control_Code:96: error: ISO C++ forbids in-class initialization of non-const static member 'over'
Bluetooth_Control_Code:97: error: ISO C++ forbids initialization of member 'pressed'
Bluetooth_Control_Code:97: error: making 'pressed' static
Bluetooth_Control_Code:97: error: ISO C++ forbids in-class initialization of non-const static member 'pressed'
Bluetooth_Control_Code:119: error: declaration of 'boolean Button::pressed()'
Bluetooth_Control_Code:97: error: conflicts with previous declaration 'boolean Button::pressed'
Bluetooth_Control_Code:125: error: declaration of 'boolean Button::over()'
Bluetooth_Control_Code:96: error: conflicts with previous declaration 'boolean Button::over'
Bluetooth_Control_Code.ino: In member function 'void Button::update()':
Bluetooth_Control_Code:103: error: 'currentcolor' was not declared in this scope
Bluetooth_Control_Code:103: error: 'highlightcolor' was not declared in this scope
Bluetooth_Control_Code:105: error: 'currentcolor' was not declared in this scope
Bluetooth_Control_Code:105: error: 'basecolor' was not declared in this scope
Bluetooth_Control_Code.ino: In member function 'boolean Button::pressed()':
Bluetooth_Control_Code:112: error: could not convert '((Button*)this)->Button::over' to 'bool'
Bluetooth_Control_Code:138: error: expected initializer before 'Button'
Please could someone point me in the right direction? Am I supposed to add the second section of the code to the first?
Any help would be hugely appreciated and I apologise for asking dumb questions!
Thanks
Alex
import is a Processing statement, not an Arduino statement. You can't compile Processing code using the Arduino IDE.
That makes sense but how is this done?
Thanks for your help
Using the Processing IDE obtained from http://Processing.org.
Awesome! Thanks for your help. Downloading now so will see what I can do!
Thanks again
