error: multiple definition of `func1()'
Please disregard this first post and scroll down to Reply #5.
How to resolve this error?
In file included from directories.ino:2:
/file1.cpp: In function 'void func1()':
file1.cpp:4: error: 'Serial' was not declared in this scope
#include "file1.cpp"
	Serial.println("in setup");
	Serial.println("in loop");
	func1();
	while(true) { }
#include <Arduino.h>
#include <Serial.h>
void func1() // error: 'Serial' was not declared in this scope
	Serial.println("in func1");
I am using Aruduinio IDE 1.0.5r-2
Thank you.
You need to correct your title. The error is actually 'Serial' was not declared in this scope
Try adding #include <Serial.h> ????
...R
Where is Serial**.begin(115200)**?
Thanks Robin2 and HazardsMind.
I added "#include <Serial.h>" to both files.
I added "Serial.begin(115200)" to setup() (I should have caught that :blush:).
But the same error persists :~.
What board are you using? Isn't it SerialUSB or something on one of them?
Belay that, you only get the error in file1 I gather.
Rob
Now I get a different error:
file1.cpp.o: In function func1()': C:\Users\wolf\AppData\Local\Temp\build6950440914927975083.tmp/file1.cpp:4: multiple definition of func1()'
directories.cpp.o:/file1.cpp:6: first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
directories.ino:
#include <Serial.h>
	func1();
	while(true) { }
file1.cpp:
#include <Serial.h>
void func1()
Apprenetly Arduino can include .h files, but not .cpp files.
This works:
#include "file1.h"
	func1();
	while(true) { }
file1.h:
void func1()
ok, live and learn eh?
Rob
wolfv:
I'm not at all a C/C++ expert but my understanding is that .cpp files are never included.
This post has a lot of useful info.
...R
Any file can be included via #include directive. To include cpp is the same as it will be copied whole source exactly at the place where directive is. The problem is, if it is included cpp and arduino IDE adds the same file into project, then first will be added via project and second will be added via directive. Try to use different extension which is not recognized by IDE e.g. .cxx and if you use #include it will be OK.
Place the include inside a namespace, and call that version.
namespace Foo{
  #include "test.cpp"
  Serial.begin( 9600 );
  Foo::func();
void loop() {}
void func(){ Serial.print( "HI" ); }
Or use ifdef guards to prevent showing the definitions when not included.
Wrong. What is happening is that the contents of the file1.cpp file are being included in the cpp file created from the ino file, which is compiled, resulting in one instance of func1. Then the file1.cpp file is compiled, resulting in another instance of func1. The linker then can't figure out which instance it should include.
Budvar10:
Thanks Budvar10, that's a good explanation.
