error: no match for 'operator=' (operand types are 'CFileVar<unsigned char>' and
This is another compile error I just don’t understand.
error: no match for ‘operator=’ (operand types are ‘CFileVar’ and ‘uint8_t {aka unsigned char}’)
What is the compiler complaining about exactly? The data types match!
In my ino file - the code in bold is generating the compiler error.
#define REBOOT    (uint8_t)0
#define HTTP_REQ  (uint8_t)2
#define TIMER     (uint8_t)3
#define MANUAL    (uint8_t)4
CFileVar<uint8_t> nWakeupType("wake", eUInt8);
void wakeupCommon()
  nPowerDownTrigger = millis() + nInactivityTime;
  PowerManager.detachInterrupts();
  resetESP();
  WifiManager.begin();
void wakeupHTTPISR()
  wakeupCommon();
  PowerManager.turnOnDevices();
  PowerManager.turnOffDevices();
  [b]nWakeupType = HTTP_REQ;[/b]
  nWakeupType.save();
typedef enum {eBool, eChar, eInt8, eUInt8, eInt16, eUInt16, eInt32, eUInt32, eFloat, eDouble, eString} enumDataType;
template<class T>
class CFileVar
	public:
		// Construction, destruction and initialisation
		CFileVar(const char* strName, enumDataType eDataType);
		CFileVar(const __FlashStringHelper* strName, enumDataType eDataType);
		virtual ~CFileVar();
		// Interface
		void set(T &tVal);
		void save();
		void restore();
		// Operators
		T& operator =(T &tVal);
		operator T&()
		  return m_tVal;
	protected:
		// Data
		CBuff<9> m_buff;
		CString m_strFilename;
		static uint8_t m_nVarNum;
		T m_tVal;
		enumDataType m_eDataType;
template<class T>
uint8_t CFileVar<T>::m_nVarNum = 1;
template<class T>
CFileVar<T>::CFileVar(const char* strName, enumDataType eDataType)
	m_strFilename = strName;
	m_strFilename += F(".txt");
	m_eDataType = eDataType;
	restore();
template<class T>
CFileVar<T>::CFileVar(const __FlashStringHelper* strName, enumDataType eDataType)
	restore();
template<class T>
CFileVar<T>::~CFileVar()
template<class T>
void CFileVar<T>::save()
	if (SD.exists(m_strFilename))
		CTextFile file;
		if (file.open(m_strFilename, REWRITE))
			file.writeLine(m_tVal);
			file.close();
			debug.logFileOpenError(m_strFilename);
		debug.logFileFoundError(m_strFilename);
template<class T>
void CFileVar<T>::restore()
	CBuff<17> buff;
	CString strVal(buff);
		CTextFile file;
		if (file.open(m_strFilename, READ))
			file.readLine(strVal);
			if (m_eDataType == eBool)
				m_tVal = strVal == F("1");
			else if (m_eDataType == eChar)
				m_tVal = strVal[0];
			else if ((m_eDataType == eInt8) && (m_eDataType == eInt16) && (m_eDataType == eInt32))
				m_tVal = strVal.toInt();
			else if ((m_eDataType == eUInt8) && (m_eDataType == eUInt16) && (m_eDataType == eUInt32))
			else if ((m_eDataType == eFloat) || (m_eDataType == eDouble))
				m_tVal = strVal.toReal();
			else if (m_eDataType == eString)
				m_tVal = strVal;
			file.close();
template<class T>
void CFileVar<T>::set(T &tVal)
	m_tVal = tVal;
template<class T>
T& CFileVar<T>::operator =(T &tVal)
	set(tVal);
	return m_tVal;
Never mind I worked it out in the end.
The compile error was a red herring and had nothing to do with the actual data type.
It was actually related to the references to the data type that i have in my template class.
