ERROR : no matching function for call to 'BH1750FVI::BH1750FVI()'
why my program error? can you please help me
this is my program
#include <Wire.h>
#include <BH1750FVI.h>
BH1750FVI LightSensor;
void setup() { // put your setup code here, to run once:
LightSensor.begin();
LightSensor.SetAddress(Device_Address_H);
LightSensor.SetMode(Continuous_H_resolution_Mode);
Serial.println(“Running…”);
uint16_t lux = LightSensor.GetLightIntensity();// Get Lux value
Serial.print(“Light: “);
Serial.print(lux);
Serial.println(” lux”);
Read the how to use this forum-please read stickies to see how to post code and some advice on how to ask an effective question.
Post the entire error messge. Paraphrasing the error message leaves out important information.
Did you get this sorted out?
First: this post belongs in the section Sensors on this forum, not here!
The BH1750 is a photometer. You do not need arcane libraries; <wire.h> suffices.
Here is a ‘bare bones’ sketch. Should work with an Arduino Uno/Nano if you connect SCL of the BH1750 to arduino pin A5, and SDA to arduino pin A4. Do not forget 4.7k pullup for both SCL and SDA’ .
Output is to Serial Monitor.
Succes :slight_smile:
// BH1750_nano_serial_monitor_nn
// with smoothing (averaging) function
// by Photoncatcher
// 1 March 2020
// public domain
// pins BH1750: SCL (yellow color code) to pin A5 of Nano, SDA (green color code) to pin A4 of Nano - pullup 4.7 k both pins
// BH1750 I2C address 0x23
// BH1750 is a 3.3V light sensor - works with 5V
  #include <Wire.h>
  int    BH1750_Device = 0x23;                                       // I2C address for BH1720 light sensor
  unsigned int lux, Scaled_FtCd, lux_av;
  float  FtCd, wattsm2;
  int    iteration = 0;
  int    iteration_time = 3000;
   Serial.begin (9600);
   Serial.println("BH1750");
   Wire.begin ();
   Wire.beginTransmission (BH1750_Device);
   Wire.write (0x10);                                                  // sets resolution to 1 Lux
   Wire.endTransmission ();
   delay (200);
   iteration++;
   lux = BH1750_Read();
   lux_av= (lux_av + lux)/2;
   FtCd = lux_av/10.764;
   wattsm2 = lux_av/683.0;
   Serial.print ("iteration: ");
   Serial.println (iteration);
   Serial.print ("Watts per square meter: ");
   Serial.println (wattsm2,4);
   Serial.print ("lux = ");
   Serial.println (lux_av);
   Serial.println ();
   delay (iteration_time);
// subroutine
 unsigned int BH1750_Read() {
   unsigned int i=0;
   Wire.requestFrom (BH1750_Device, 2);
   while(Wire.available ())
     i <<=8;
     i|= Wire.read();
   Wire.endTransmission();
   return i/1.2;  // Convert to Lux
