Error: No matching function for call to
Hey,
So I'm working on a science project. I found this code for a project on Github and when trying to verify it, it gives me the error: No matching function for call to 'Adafruit_Fingerprint::Adafuit_Fingerprint(SoftwareSerial)'
Any help would be appreciated but, please speak english.
:slight_smile:
#include <Servo.h>
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, 6, NEO_GRB + NEO_KHZ800);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(4, 5);
#else
NewSoftSerial mySerial(4, 5);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
The library is probably expecting a pointer to a hardware serial object, and doesn't know what to do with a SoftwareSerial object pointer.
Please remember to use code tags when posting code.
AWOL:
Umm, here's the start of one of Adafruit's example sketches included with the fingerprint library:
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
// uncomment this line:
// #define mySerial Serial1
// For UNO and others without hardware serial, we must use software serial...
// comment these two lines if using hardware serial
SoftwareSerial mySerial(2, 3);
Pointer to software serial should be OK.
I see your point (I don't have the library) but the compiler seems to disagree.
Which board are you using?
class Adafruit_Fingerprint {
 public:
#if defined(__AVR__) || defined(ESP8266)
  Adafruit_Fingerprint(SoftwareSerial *ss, uint32_t password = 0x0);
#endif
  Adafruit_Fingerprint(HardwareSerial *hs, uint32_t password = 0x0);
ERRoR IS:no matching function for call to 'Adafruit_Fingerprint::Adafruit_Fingerprint(SoftwareSerial*)'
how to solve this error
gopalreddy:
Read the comment directly above yours. I'm willing to bet you're not using an AVR. If that's the case, then you can't use SoftwareSerial with this class.
