error occurred in compile header file
I proting my function code to header file. but many error is bothering me. So, i want to know cause of error. Or, i hope you to write header file code for me. please help me. And i write my header and function code.
This is original function.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void korean(int i, int n)
  if (i == 1) //1!
    byte a_1[8] = {
      B00000,
      B00000,
      B00010,
      B11010,
      B01011,
      B01010,
      B00010,
      B00010,
    lcd.createChar(n, a_1);
    lcd.setCursor(n - 1, 0);
    lcd.write(byte(n));
  else if (i == 2) //2!
    byte a_1[8] = {
      B00000,
      B00010,
      B11011,
      B01010,
      B01010,
      B00000,
      B11110,
      B00010,
    lcd.write(byte(n));
#endif
This is header file code.
#ifndef korean_c
#include "Arduino.h"
#include "LiquidCrystal.h"
void korean(LiquidCrystal &lcd, int i, int n)
    if (i == 1) //1!
        byte a_1[8] = {
            B00000,
            B00000,
            B00010,
            B11010,
            B01011,
            B01010,
            B00010,
            B00010,
        lcd.write(byte(n));
        byte a_1[8] = {
            B00000,
            B00010,
            B11011,
            B01010,
            B01010,
            B00000,
            B11110,
            B00010,
        lcd.write(byte(n));
This is error code.
Arduino: 1.6.5 (Mac OS X), Board: "Arduino/Genuino Uno"
In file included from sketch_oct18c.ino:1:0:
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:7:1: error: expected class-name before '{' token
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:9:12: error: expected unqualified-id before 'int'
korean_c(int i, int n);
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:9:12: error: expected ')' before 'int'
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:10:5: error: declaration does not declare anything [-fpermissive]
void korean_c;
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:13:1: error: abstract declarator '' used as declaration
Error compiling.
enabled in File > Preferences.
If you help me, Thanks a lot.
At the top of your header file, you have:-
#ifndef korean_c
but you don't then define it or have an #endif at the end.
Also, it's customary to use capitals for defines.
Instead of:-
#ifndef korean_c
type:-
#ifndef _KOREAN_C
#define _KOREAN_C
Then at the bottom of the file, below all of the code, type:-
#endif
I just did this, and then your file compiled without errors.
Here is the full, corrected header file:-
#ifndef _KOREAN_C_H
#define _KOREAN_C_H
    if (i == 1) //1!
        byte a_1[8] =
            B00000,
            B00000,
            B00010,
            B11010,
            B01011,
            B01010,
            B00010,
            B00010,
        lcd.write(byte(n));
        byte a_1[8] =
            B00000,
            B00010,
            B11011,
            B01010,
            B01010,
            B00000,
            B11110,
            B00010,
        lcd.write(byte(n));
#endif
OldSteve:
#ifndef _KOREAN_C_H
#define _KOREAN_C_H
    if (i == 1) //1!
        byte a_1[8] =
            B00000,
            B00000,
            B00010,
            B11010,
            B01011,
            B01010,
            B00010,
            B00010,
        lcd.write(byte(n));
        byte a_1[8] =
            B00000,
            B00010,
            B11011,
            B01010,
            B01010,
            B00000,
            B11110,
            B00010,
        lcd.write(byte(n));
#endif
Wow! you are very kind! Thanks a lot! :slight_smile:
Unfortunately , these errors have occurred.
In file included from TEST.ino:1:0:
void korean_c;
Error compiling.
I'm sure that someday you are going to catch on to the fact that the header file is not being compiled in isolation. Someday, the phrase "POST ALL OF YOUR CODE" is going to sink in. I'm not holding my breath, though.
PaulS:
I do not understand your words completely. I'm sorry.
However, What is ALL OF MY CODE..?
Someplace, you include that header file. THAT code needs to be posted, too.
I added your header to a blank project, with "#include <LiquidCrystal.h>" in the *.ino file, and it compiled without errors.
The corrected header is fine, the error is now elsewhere. (As Paul indicates.)
OldSteve:
Can you show me blank project source..?
chulwon0110:
You're kidding?
I already deleted it after testing. Wait a few minutes and I'll do it again.....
OK, here's my very complex blank project, which compiles fine:-
/* BareMinimum.ino
#include "korean_c.h"
// Constants:-
// Variables:-
Did you think I was lying to you?
Now go and look for the errors in your TEST.ino file.
OldSteve:
/* BareMinimum.ino
// Constants:-
// Variables:-
Thank you... I succeeded in compiling. I use korean function in balnk project from library. By the way, error occurred.
My blank source is here.
#include <Korean_c.h>
    korean(1,1);
This is error code.
TEST.ino: In function 'void setup()':
TEST:5: error: invalid initialization of non-const reference of type 'LiquidCrystal&' from an rvalue of type 'int'
/Applications/Arduino.app/Contents/Java/libraries/Korean_c/Korean_c.h:7:6: error: in passing argument 1 of 'void korean(LiquidCrystal&, int, int)'
    korean(1,1);
Why? You defined the method as taking a reference to a LiquidCrystal instance and two more values. Why are you calling it with only two values?
PaulS:
    korean(1,1);
The reason I put the instance that is LiquidCrystal.h -related error. After i put the instance, error fixed. So, i don't know about use that instance... Can you tell me about use that instance? I'm sorry...
This compiles fine:-
/* BareMinimum.ino
// Constants:-
// Variables:-
    korean(lcd,1,1);
OldSteve:
/* BareMinimum.ino
// Constants:-
// Variables:-
    korean(lcd,1,1);
Wow!!!!! You're Genius! Thanks a lot! :slight_smile:
