Error of redefinition
    Grove LED Bar - Level Example
    This example will show you how to use setLevel() function of this library.
    The setLevel() function illuminates the given number of LEDs from either side.
    Syntax setLevel(level)
    0  = all LEDs off
    5  = 5 LEDs on
    10 = all LEDs on
#include <Grove_LED_Bar.h>
  const int capteurfsr = A0;
  const int bled = 4;
  int valeur;
  int value;
//BE SURE USE CORRESPONDING DEVICE
//Grove_LED_Bar bar(6, 7, 0, LED_CIRCULAR_24);
//FOR LED_BAR_10
Grove_LED_Bar bar(7, 4, 1, LED_BAR_10); // Clock pin, Data pin, Orientation
    // nothing to initialize
    bar.begin();
    pinMode(bled, OUTPUT);
    Serial.begin(9600);       //initialisation du moniteur série
  // Walk through the levels
  valeur = analogRead(capteurfsr);       //lecture de la valeur de la pression puis elle est sauvegardée dans variable             //affichage de la valeur captée sur le moniteur série
  value = map(valeur, 0, 1023, 0, 255); //Map valeur 0-1023 en 0-255 (PWM)
  Serial.println(value);
    if ( (value>0) && (value<=25) ){
        bar.setLevel(1);
        delay(100);
    else if ( (value>25) && (value<=50) ){
        bar.setLevel(2);
        delay(100);
    else if ((value>50) && (value<=75)){
        bar.setLevel(3);
        delay(100);
    else if ((value>75) && (value<=100)){
        bar.setLevel(4);
        delay(100);
    else if ((value>100) && (value<=125)){
        bar.setLevel(5);
        delay(100);
    else if ((value>125) && (value<=150)){
        bar.setLevel(6);
        delay(100);
    else if ((value>150) && (value<=175)){
        bar.setLevel(7);
        delay(100);
    else if ((value>200) && (value<=225)){
        bar.setLevel(8);
        delay(100);
    else if ((value>225) && (value<=250)){
        bar.setLevel(9);
        delay(100);
    else if ((value>250) && (value<=255)){
        bar.setLevel(10);
        delay(100);
    else if (value==0) {
       bar.setLevel(0);
       delay(100);
C:\Users\XXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:13:13: error: redefinition of 'const int capteurfsr'
C:\Users\XXXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\Ledba.ino:13:11: note: 'const int capteurfsr' previously defined here
C:\Users\XXXXX\OneDrive\Documents\XXXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:14:13: error: redefinition of 'const int bled'
   const int bled = 4;
C:\Users\XXXOneDrive\Documents\XXXX\SIN\Fichier Arduino\Ledba\Ledba.ino:14:11: note: 'const int bled' previously defined here
 const int bled = 4;
C:\Users\XXXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:15:7: error: redefinition of 'int valeur'
   int valeur;
C:\Users\XXXX\OneDrive\Documents\XXXX\SIN\Fichier Arduino\Ledba\Ledba.ino:15:5: note: 'int valeur' previously declared here
 int valeur;
C:\Users\XXXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:16:7: error: redefinition of 'int value'
   int value;
C:\Users\XXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\Ledba.ino:16:5: note: 'int value' previously declared here
 int value;
C:\Users\XXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:20:18: error: redefinition of 'Grove_LED_Bar bar'
C:\Users\XXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\Ledba.ino:20:15: note: 'Grove_LED_Bar bar' previously declared here
C:\Users\XXX\OneDrive\Documents\XX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino: In function 'void setup()':
C:\Users\XXXX\OneDrive\Documents\XXX\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:22:6: error: redefinition of 'void setup()'
C:\Users\XXX\OneDrive\Documents\XX\SIN\Fichier Arduino\Ledba\Ledba.ino:22:6: note: 'void setup()' previously defined here
C:\Users\lvgeo\OneDrive\Documents\T2D\SIN\Fichier Arduino\Ledba\LEDBATEST.ino: In function 'void loop()':
C:\Users\lvgeo\OneDrive\Documents\T2D\SIN\Fichier Arduino\Ledba\LEDBATEST.ino:29:6: error: redefinition of 'void loop()'
C:\Users\XXX\OneDrive\Documents\XX\SIN\Fichier Arduino\Ledba\Ledba.ino:29:6: note: 'void loop()' previously defined here
exit status 1
Compilation error: redefinition of 'const int capteurfsr'
Bonjour, ci dessus mon code et mes erreurs. Je ne comprend pas ce qui ne fonctionne pas, pouvez vous m'aider ? merci beaucoup
:warning:
Post mis dans la mauvaise section, on parle anglais dans les forums généraux. déplacé vers le forum francophone.
Merci de prendre en compte les recommandations listées dans Les bonnes pratiques du Forum Francophone
Excusez moi je ne l'avais jamais utilisé et suis pressé je n'avais pas compris comment le mettre en francophone
Problème résolu
Deux .INO dans le même dossier (peut-être une ancienne copie)?
Quand on résout soi-même son problème (bravo), c'est sympa d'expliquer à la foule en attente ce qui n'allait pas.
oui clairement LEDBATEST.ino et Ledba.ino
