Error on compile -stdlib.h not found
Can any guru tell me what is wrong here ? here is the message given
/arduino-1.0/hardware/arduino/cores/arduino/Arduino.h:4:20: fatal error: stdlib.h: No such file or directory compilation terminated.
Where should this file be and what is it trying to tell me ?
Actually I expanded the window and there is more to the message
avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=100 -I/arduino-1.0/hardware/arduino/cores/arduino -I/arduino-1.0/hardware/arduino/variants/standard /tmp/build2733294214254685087.tmp/sketch_jan13a.cpp -o/tmp/build2733294214254685087.tmp/sketch_jan13a.cpp.o In file included from sketch_jan13a.cpp:3:0: /arduino-1.0/hardware/arduino/cores/arduino/Arduino.h:4:20: fatal error: stdlib.h: No such file or directory compilation terminated.
Now I found a copy of that file in /usr/include so I added that directory to my PATH That did not fix it so I added that to my LD PATH That didn't fix it either ?
stdlib.h is part of the C/C++ standard library.
It should be under hardware/tools/avr/avr/include.
Looks like the avr-g++ installation is bad.
Yes Thanks .Thats on a Windows system I am on a Linux system where the avr-g++ is installed by downloading , compiling and installing . These are obtained from mirror repositories and I have tried a few versions from a few mirrors to no avail.
Are you having the problems with windows or linux? What distro? Do I see that you have arduino installed in the root directory? That sounds like a bad idea.
I am on a Linux system . Puppy Linux 5.3 in fact Arduino is installed in my home directory but as I am root it matters not. My problem is with "stdlib.h" How does your post help me if thats what you intended? I just wonder if you read my posts at all before posting your reply?
tytower: I am on a Linux system . Puppy Linux 5.3 in fact Arduino is installed in my home directory but as I am root it matters not. My problem is with "stdlib.h" How does your post help me if thats what you intended? I just wonder if you read my posts at all before posting your reply?
I have/had the same problem. And actually johnwasser gave the correct answer that helped me solve the problem.
I am using Lubuntu 11.10 and because of John's answer I looked if there was something not installed for the avr compilation system. And hey guess what there was. I found it in Synaptic avr-libc was not installed. I installed it and all was right with the world.
And tytower I suggest you find a way to deal with your stress a little better. Everybody that answered was trying to help you. Just as I am now.
[Moderator edit : Unwarranted vitriol removed. AWOL]
It appears that the culprit is Puppy Linux 5.3 Version 5.3.1 runs Arduino well and I would say they patched it following my posts
[Moderator edit : More unwarranted vitriol removed. AWOL]
tytower: It appears that the culprit is Puppy Linux 5.3 Version 5.3.1 runs Arduino well and I would say they patched it following my posts
So you're saying my question regarding what distro you're using was relevant?
