error on eeprom
hello guy, i need some help here
i get some error at maxpeople , my people
#include <EEPROM.h>
#define DEBUG 1         // We want to see debug print statements
// Comment out these lines to avoid seeing print
statements
const int MAXPEOPLE = 10;
struct servicePeople {                  // Structure definition for servicePeople
  int ID;
  char Name[20];
  char PW[10];
  long Phone;
union servicePeopleUnion {                      // A union definition for myUnion
  int testID;
  struct servicePeople testServicePeople;
myUnion;
servicePeople myPeople[MAXPEOPLE] = {   // company data for testing
    0, "This is a dummy","admin",5555555          }
    101,"Kack Lawn Service","Clowder",2345678          }
    222,"Jane's Plants","Noah",4202513          }
    333,"Terrys Pool Service","Billings",4301832          }
// function declarations:
void DataDump(struct servicePeople temp);
int FindEepromTop();
int ReadIntFlag();
void ReadOneRecord(int index);
void WriteFirstRecord();
int loopCounter = 0;           // Number of passes to make through loop
int initFlag = 0;              // Has the EEPROM been initialized?
struct servicePeople temp;             // A temporary structure
  int eepromMax;
  int i;
  eepromMax = FindEepromTop();        // How much EEPROM?
  Serial.print("EepromMax = ");
  Serial.println(eepromMax);
  initFlag = ReadIntFlag(); // Initialized?
  Serial.print(" flag = ");
  Serial.println(initFlag);
  for (i = 0; i < MAXPEOPLE; i++) {
    WriteOneRecord(i);
int FindEepromTop()
  return E2END + 1;
int ReadIntFlag()
  int *ptr = &myUnion.testID;
  *ptr = EEPROM.read(0);
  return myUnion.testID;
void WriteOneRecord(int index)
  byte *b;
  int i;
  int offset = index * sizeof(servicePeople);
  b = (byte *) &myPeople[index];    // Going to write this record
  for (i = 0; i < sizeof(servicePeople); i++)
    EEPROM.write(i + offset, *b++);
  static int eepromIndex = 1; // Assume there are records
  loopCounter++;
  if (initFlag > 0) { // There are records to read
    ReadOneRecord(eepromIndex++);
    if (myUnion.testServicePeople.ID != 0) { // Read some real data
      DataDump(myUnion.testServicePeople);
  else {
    eepromIndex++;      // Make sure loop can end with no records.
  Serial.println("==========");
  if (eepromIndex == MAXPEOPLE) {
    TerminationStep(1);
  byte *bPtr;
  int i;
  int offset;
  offset = index * sizeof(servicePeople); // must offset from 0 in EEPROM
  bPtr = (byte *) &myUnion.testServicePeople;         // where to place the data read
  for (i = 0; i < sizeof(temp); i++) { // Loop through the bytes…
    *bPtr = EEPROM.read(offset + i);
    bPtr++;
  Serial.print("ID = ");
  Serial.print(temp.ID);
  Serial.print(" Name = ");
  Serial.println(temp.Name);
  Serial.print(" PW = ");
  Serial.print(temp.PW);
  Serial.print(" Phone = ");
  Serial.println(temp.Phone);
"statements" This appears to be a line that was supposed to be a comment?
// statements
Later on, you call
TerminationStep(1);
which is not defined yet.
how to i write the TerminationStep code
Don't know, not sure what your code is doing.
my code is to read out the data record in the eeprom
some how the data base.
The TerminationStep(1) only seems to do with checking the max # of people (records), no idea what the code is to do within loop() if that number is reached.
i need to get this image out
I would just change this line then to stop reading after reaching the end:
if ( (initFlag > 0) && (loopCounter <=MAXPEOPLE) ) { // There are records to read, and not at the end yet
and take out the terminationStop section.
i change already. but still cannot at all
