I've include the MPU6050 library into my project and when I compile I get the following error:
d:\Development\CSense\C-Sense2.0\libraries\MPU6050/MPU6050.h:57:37: error: expected identifier before numeric constant
#define MPU6050_ADDRESS_AD0_HIGH 0x69 // address pin high (VCC)
When i change the name of MPU6050_ADDRESS_AD0_HIGH to something like MPU6050_ADDRESS_AD0_HIGG everything compiles fine! (Well of course I do get errors about ..HIGH not being defined but no error on the #define..
If I change it back again to ..HIGH then the original error comes up again.
Never mind ... though the error was marked in line containing the #define it was actually caused by the line where the defined constant was used. I used the wrong braces when declaring an object with the define as a parameter..
Well .. the code wouldn't have made you much the wiser... As I wouldnt have thought of adding the code where the define is used (and my project contains over 40 source files)
#define MPU6050_ADDRESS_AD0_HIGH 0x69 // address pin high (VCC).
Anyway I learned that when the error location indication is a #define I should look at the use of that define which is kinda logical as that is the first time where the text substitution takes place
