Error on installing node js
Following the tutorial https://blog.arduino.cc/2014/07/07/node-js-on-the-arduino-yun/
But I am getting error on installing node...
root@Arduino:~# opkg update Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz. okUpdated list of available packages in /var/opkg-lists/attitude_adjustment. Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig. Signature check passed. root@Arduino:~# opkg install node Installing node (v0.10.33-1) to root... Downloading http://downloads.arduino.cc/openwrtyun/1/packages/node_v0.10.33-1_ar71xx.ipk. Installing uclibcxx (0.2.4-1) to root... Downloading http://downloads.arduino.cc/openwrtyun/1/packages/uclibcxx_0.2.4-1_ar71xx.ipk. Installing v8m-rb (3.14.5-git-2) to root... Downloading http://downloads.arduino.cc/openwrtyun/1/packages/v8m-rb_3.14.5-git-2_ar71xx.ipk. Installing libstdcpp (4.6-linaro-1) to root... Downloading http://downloads.arduino.cc/openwrtyun/1/packages/libstdcpp_4.6-linaro-1_ar71xx.ipk. Configuring libstdcpp. Configuring uclibcxx. Configuring v8m-rb. Collected errors: * wfopen: /usr/bin/node: No space left on device. * extract_archive: Cannot create symlink from ./usr/bin/npm to '/usr/lib/node_modules/npm/bin/npm-cli.js': No space left on device. * pkg_write_filelist: Failed to open //usr/lib/opkg/info/node.list: No space left on device. * opkg_install_pkg: Failed to extract data files for node. Package debris may remain! * opkg_install_cmd: Cannot install package node. * opkg_conf_write_status_files: Can't open status file //usr/lib/opkg/status: No space left on device.
Any help? Thanks
Just to take it on point my firmware is the last available and the Yun is out of the box a day ago.
It says no space on device. Maybe you'll have to install it on a sd card.
mart256: It says no space on device. Maybe you'll have to install it on a sd card.
Correction: He will need to install an SD card. I've made the same mistake and had to reinstall the Yun OS and then reinstall nodejs.
To be clear, start over make sure you have an SD card for storage.
Upgrading the OpenWrt-Yun image on the Yún https://www.arduino.cc/en/Tutorial/YunSysupgrade
How to expand the Yún disk space https://www.arduino.cc/en/Tutorial/ExpandingYunDiskSpace
Also make sure the Date is correctly set on your Yun, else your downloads will fail. This is an issue the Yun. The only work around is to make sure the date and time zone is set correctly.
Jesse
