/Volumes/Alexei Backup/08 Sketches and Libraries/sketches/1Ultrasonic_people_counter/1Ultrasonic_people_counter.ino:14:32: warning: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
LiquidCrystal_I2C LCD(0x3F,16,2);
In file included from /Volumes/Alexei Backup/08 Sketches and Libraries/sketches/1Ultrasonic_people_counter/1Ultrasonic_people_counter.ino:1:0:
/Users/alexei/Documents/Arduino/libraries/jm_LiquidCrystal_I2C/LiquidCrystal_I2C.h:55:2: note: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)'
LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
/Volumes/Alexei Backup/08 Sketches and Libraries/sketches/1Ultrasonic_people_counter/1Ultrasonic_people_counter.ino: In function 'void setup()':
1Ultrasonic_people_counter:17: error: 'lcd' was not declared in this scope
lcd.begin();
/Volumes/Alexei Backup/08 Sketches and Libraries/sketches/1Ultrasonic_people_counter/1Ultrasonic_people_counter.ino: In function 'void loop()':
1Ultrasonic_people_counter:35: error: 'lcd' was not declared in this scope
lcd.setCursor(10, 0);
Multiple libraries were found for "LiquidCrystal_I2C.h"
Used: /Users/alexei/Documents/Arduino/libraries/jm_LiquidCrystal_I2C
Not used: /Users/alexei/Documents/Arduino/libraries/Arduino-LiquidCrystal-I2C-library-master
If you would take the time to read the stickies, you can see that you should include your code in code tags.
Like this
#include <LiquidCrystal_I2C.h> // Call on the libraries
#include <NewPing.h>
#include <Wire.h>
#define TRIGGER_PIN 7 // Ultrasonic sensor trig to Arduino pin 7
#define ECHO_PIN 8 // Ultrasonic sensor echo to Arduino pin 8
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
int LEDPin = 13; // Set LED to pin 13
int distance; // Variable for distance
int people = 0; // Variable for number of people
boolean count = false; // State for counting
LiquidCrystal_I2C lcd(0x27, 16, 2);
void setup() { // Run once to set up the LCD screen and LED
lcd.begin();
lcd.backlight();
pinMode(LEDPin, OUTPUT); // Set the LED as an output
lcd.print("People:"); // Print People: to the LCD screen
void loop() { // This loops forever to check for number of people
delay(50);
distance = sonar.ping_cm();// Ping every 50 milliseconds
// If more than 100cm away, don't count
if ( distance > 100 && count ) {
count = false;
digitalWrite(LEDPin, LOW);
// If less than 100cm away, count 1
if ( distance < 100 && distance != 0 && !count) {
count = true;
people ++; // Keep adding 1 per count
digitalWrite(LEDPin, HIGH);
lcd.print(people); // Print number of people to LCD screen
it's the </> symbol in the top left. STRG+T before if necessary.
Regarding your code you defined LCD but use lcd later on. These declarations should be case sensitive and therefore you should either declare lcd in the beginning or use LCD in your code, up to you.
Also you should take care of this error
[b] LiquidCrystal_I2C LCD(0x3F,16,2);[/b]
It looks like the OP may have posted the error message from a different version of the program
1Ultrasonic_people_counter:17: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
LCD.begin();
/Volumes/Alexei Backup/08 Sketches and Libraries/sketches/1Ultrasonic_people_counter/1Ultrasonic_people_counter.ino:17:13: note: candidate is:
/Users/alexei/Documents/Arduino/libraries/jm_LiquidCrystal_I2C/LiquidCrystal_I2C.h:112:15: note: virtual void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
virtual void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS);
/Users/alexei/Documents/Arduino/libraries/jm_LiquidCrystal_I2C/LiquidCrystal_I2C.h:112:15: note: candidate expects 3 arguments, 0 provided
exit status 1
After I have resulted from this problem I get a second error please help google does not give it to me clearly.
Here is the code:
#include <Wire.h>
LCD.begin();
LCD.backlight();
LCD.print("People:"); // Print People: to the LCD screen
delay(50);
count = false;
count = true;
LCD.setCursor(10, 0);
LCD.print(people); // Print number of people to LCD screen
And here is the error:
LCD.begin();
exit status 1
My post wasn't accessible anymore since the other topic was locked. Here's it again in condensed form:
You are using 2 libraries with the same name (did you rename one of them manually?). Which libraries documentation are you looking at? Post the link. Get rid of the other one. The one used by the IDE most likely doesn't take begin() empty or at all, don't know. Hard to tell without looking at it.
