ERROR ON MY ARDUINO UNO
Hi I just experience a problem on my arduino uno. My program wont upload to the board and I cant use anymore the external reset button. I tried the Loop back test but i cant hear any echo on it.
I already used this board and it is working last night I test it now with another code and use a motor shield then suddenly it cannot upload anymore
I checked the device manager the Com port where it is plugged in is USB Port is that correct? I think it should be Arduino Uno..
An error message pop up and said:
Sketch uses 1150 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x16
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Please help
Loopback test fails with nothing connected to pins 0, 1?
Do you have ~5V on the 5V pin,
Do you have 3.3V on the 3.3V pin?
Is the Reset pin at ~5V?
Is the USB/Serial chip next to the USB connector hot?
Is the 328P chip hot?
Those things not being as stated could indicate what's wrong with your board.
Often the Atmega16U2 chip next to the USB connector gets zapped, and then serial comm's stop working.
i shorted pin 1 and 2... shorted also the grd to reset.. Both chips are not that hot...
For the loopback test, you need to short pins 0 and 1, not 1 and 2.
sorry my error .. yes i shorted 0 - 1 TX and RX pin
