Hello There!.I am still amateur to the arduino.so apologies in advance if u find any silly mistakes. I have been trying to store GPS data gathered through my ublox M8N module in 16 gb FAT32 SanDisk sd card. But an erratic error is occurring. Mostly my data.txt file would not be even created but even if it was created sometimes, anything could not be written onto it. pls help me out as i am perplexed why it is not working properly.All the physical connections and individual units are working properly,but when i latch all together, it becomes messy.
The message displayed on serial was-"error opening data.txt"
This is the code-
#include<SD.h>
#include<SPI.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
static const int RXPin = 3, TXPin = 2;
static const uint32_t GPSBaud = 9600;
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
TinyGPSPlus gps;
File myFile;
SoftwareSerial ss(RXPin, TXPin);
void displaySensorDetails(void)
sensor_t sensor;
mag.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
ss.begin(GPSBaud);
Serial.println(F("Simple Test with TinyGPS++ and attached NEO-6M GPS module"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
displaySensorDetails();
pinMode(10, OUTPUT);
if (SD.begin(4)) {
Serial.println("Initialization Successful");
else {
Serial.println("Initialization Failed");
if (SD.exists("data.txt")) { //Delete old data files to start fresh
SD.remove("data.txt");
myFile = SD.open("data.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to data.txt...");
myFile.print("GPS Testing");
Serial.println("done.");
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening data.txt");
sensors_event_t event1;
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayGpsInfo();
if (myFile) {
if (gps.location.isValid())
myFile.print("Location: ");
myFile.print(gps.location.lat(),6);
myFile.print(",");
myFile.print(gps.location.lng(), 6);
if (gps.date.isValid())
myFile.print(" Date/Time: ");
myFile.print(gps.date.month());
myFile.print("/");
myFile.print(gps.date.day());
myFile.print("/");
myFile.print(gps.date.year());
if (gps.time.isValid())
if (gps.time.hour() < 10) myFile.print(F("0"));
myFile.print(gps.time.hour());
myFile.print("/");
if (gps.time.minute() < 10) myFile.print(F("0"));
myFile.print(gps.time.minute());
myFile.print("/");
if (gps.time.second() < 10) myFile.print(F("0"));
myFile.print(gps.time.second());
if (gps.time.centisecond() < 10) myFile.print(F("0"));
myFile.println(gps.time.centisecond());
myFile.print("X: "); myFile.print(event1.magnetic.x); myFile.print(" ");
myFile.print("Y: "); myFile.print(event1.magnetic.y); myFile.print(" ");
myFile.print("Z: "); myFile.print(event1.magnetic.z); myFile.print(" ");myFile.print("uT");
myFile.close();
void displayGpsInfo()
// Prints the location if lat-lng information was recieved
Serial.print(F("Location: "));
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(gps.altitude.meters(),6);
// prints invalid if no information was recieved in regards to location.
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
if(mag.begin())
displayCompassInfo();
void displayCompassInfo()
sensors_event_t event;
mag.getEvent(&event);
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" ");Serial.println("uT");
float heading = atan2(event.magnetic.y, event.magnetic.x);
float declinationAngle = -0.041;
heading += declinationAngle;
if(heading < 0)
heading += 2*PI;
if(heading > 2*PI)
heading -= 2*PI;
float headingDegrees = heading * 180/M_PI;
Serial.print("Heading (degrees): "); Serial.println(headingDegrees);
