what should i do yet? there is the error overring baud rate 115200. and i don't know how to fix it
The proverbial crystal ball is still in the dishwasher...
➜ Please do yourself a favor and read How to get the best out of this forum. Post accordingly, including necessary details...
Please post the whole error that you are having.
And please post the error using the code formatter:
_________________________________/
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x43
I am fairly sure I have seen several hundred of this error. There is a search feature on the forum, hint!
usual suspects
- did you select the right board / options for that board?
- did you select the right port?
- do you have a data USB cable in good conditions?
- do you need a driver for that Arduino?
- do you have the right boot loader in your arduino ?
You probably have selected the wrong board and or boot loader. Click the button under the dishwasher and you will find it.
