// Script starts
#include <Separador.h>
Separador s; // Library to separate the obtained results from the smartphone
// Circuit variables definition
int a = 9; // PWM output pin, 254 resolution bits
int ap = 10; // +5V supply for opamp
int an = 7; // ICL7660 supply, turns +5V to -5V for opamp
int a1 = 12; // ICL7660 supply, turns +5V to -5V
int a2 = 2; // +5V for Bluetooth module
int R2 = 330; // Used in operating potential window equation
int R3 = 510;
int R4 = 200;
int val ;
float ct = A0; // ADC analog input pin, 1024 resolution bits
float c; // Current in bits
float cc;
// Redefinition of variables obtained from the smartphone
float Estep;
int t;
int t_print;
TCCR1B = TCCR1B & B11111000 | B00000001; // Changes pin 9 frequency to 3.1kHz
pinMode(a,OUTPUT); // Output pin
pinMode(a1,OUTPUT);
pinMode(a2,OUTPUT);
pinMode(ap,OUTPUT);
pinMode(an,OUTPUT);
pinMode(ct,INPUT); // Input pin, current lecture
delay(2500);
digitalWrite(an,1); // Negative supply of opamp
digitalWrite(ap,1); // Positive supply of opamp
delay(30000);
digitalWrite(a2,1); // Bluetooth on
delay(5000); // Time (ms)
if (Serial.available()){
String e = Serial.readString();
String e1 = s.separa(e,',',0);
String e2 = s.separa(e,',',1);
String e3 = s.separa(e,',',2);
String e4 = s.separa(e,',',3);
String e5 = s.separa(e,',',4);
String e6 = s.separa(e,',',5);
String e7 = s.separa(e,',',6);
String e8 = s.separa(e,',',7);
int ee1 = e1.toInt(); // E0 mV
int ee2 = e2.toInt(); // Ei mV
int ee3 = e3.toInt(); // Ef mV
int ee4 = e4.toInt(); // Scan speed mV/s (vb)
int ee5 = e5.toInt(); // Cycle number
int ee6 = e6.toInt(); // Estep mV and time_step ms for chronoamperometry
int ee7 = e7.toInt(); // Time of potential application
int tech = e8.toInt(); // Electrochemical technique number
float Eii = ee2/1000.0; // Input of initial V, the smaller value from -1.5V to 1.5 V
float Ei = (Eii+(200.0/510.0)*4.70); // Transformation of the initial potential to Arduino
int ti = Ei*(255.0/(5.5*(200.0/330.0)));
float Ei0 = ee1/1000.0;
float E0 = (Ei0+(200.0/510.0)*4.70);
int start = E0*(255.0/(5.5*(200.0/330.0)));
float Ef0 = ee3/1000.0; // Input of end potential, the greater number from -1.5V to 1.5 V
float Ef = (Ef0+(200.0/510.0)*4.7); // Transformation of the end potential
int fin = Ef*(255.0/(5.5*(200.0/330.0))); // Final potential, Arduino scale, Ei<Ef
int vb = ee4; // Scan rate, mV/s, max = 1280 mV/s
int const count = ee5; // Cycles number
float Potstep = ee5/255.0; // Fixed due to the DAC resolution
long t=(5000000L)/(256L*vb);
int time_tot = ee7*-1000; // Time (ms)
int tot_time = time_tot/ee6;
int val;
// Electrochemical methods
switch (tech){
// ------ Chronoamperometry------
case 1:
digitalWrite(a1,1);
for(int n = 1; n < tot_time; n++){
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(ti);
Serial.print(";");
analogWrite(a,ti);
c = analogRead(ct);
cc = (0.472*(analogRead(ct))-226.1);
Estep = (1.843-(val*0.014379));
Serial.print(c);
Serial.print(";");
Serial.print(n*ee6);
Serial.print(";");
Serial.println(cc);
int sec = ee6*1000;
delay(sec);
// ------Linear voltammetry------
case 2:
digitalWrite(a1,1);
// Anodic scan
if (Ei < Ef) {
for(int n = 1; n <= count; n++){
for(int val = ti; val < fin; val++){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(Estep);
Serial.print(";");
Serial.println(cc);
delay(t);
// Cathodic scan
else if (Ei >= Ef) {
digitalWrite(a1,1);
for(int val = ti; val > fin; val--){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
// ------Cyclic voltammetry------
case 3:
digitalWrite(a1,1);
// Anodic scan
if (Ei < Ef) {
// Start the forward scan
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
// Start the reverse scan
for(int val = fin; val > start; val--){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
ti = start;
// Cathodic scan
//Start the forward scan
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
//Start the reverse scan
for(int val = fin; val < start; val++){
analogWrite(a,val);
Serial.print("#c");
Serial.print(1);
Serial.print(";");
Serial.print(val);
Serial.print(";");
c = analogRead(ct);
Serial.print(c);
Serial.print(";");
Serial.print(";");
Serial.println(cc);
delay(t);
ti=fin;
//Script ends
