Hello,
I have a project with two separate files, which we'll call A.ino and B.ino. Inside A.ino, I have the methods and objects relevant to making the program run, while B.ino is a standard library for one of the IMU's from SparkFun.
So far, so good. When the code compiles in the Arduino IDE, the compiler sees both files and it does what I expect it to do. Normally, everything is fine.
The problem I'm having is whenever the compiler hits any sort of bug. Before I included B.ino, the compiler would highlight the line with the error in A.ino and the error messages were very relevant. After including B.ino, the line it highlights is always at the end of B.ino, despite the errors occurring in A.ino. To make matters worse, the error messages are sometimes very basic and can give little-to-no information about where the problem is.
Luckily, with a bit of tinkering I've been able to keep things moving forward, but it's frustrating that the IDE no longer points out exactly where the problems are occurring.
Does this sound like anything you've ever experienced? Is there a logical reason that this is happening? What can I do to fix this issue?
