I tried to compile an old arduino code that was working earlier, but now I get the following error message:
In function ‘void loop()’: error: ‘printInteger’ was not declared in this scope
This is weird, because I have used this code earlier without any problems and I havent changed it since. Isnt ‘printInteger’ a arduino function and should therefore be part of the arduino software?
I think printInteger used to be in the wiring_serial code but it looks like it has been removed from the latest releases.
To fix the problem, try replacing printInteger with Serial.print
Post a link to this in the bugs an suggestions thread so mellis can comment and remove printInteger from the language reference if its no longer supported.
