Error regarding 'undeclared variable in scope' [SOLVED]
Hello! I'm new to the community (and am a novice coder) and am currently working on my Graphic Design thesis project involving the Arduino. Specifically, I'm using the Sparkfun RedBoard.
CONTEXT
I'm currently doing a trial setup of a capacitive proximity sensor and I have an LED connected that I want to have light up when an item is close enough to trigger the sensor. I'm slowly figuring things out and am combining knowledge and code from various tutorials and projects that I've found and/or tried. In my first attempt at the coding, I was successful at getting the capSensor to respond as desired and the serial monitor was showing correct inputs. I tried adding a LED dim/bright code (triggered by the sensor values) by mapping and constraining the inputs into a different output for the LED. The results were... off. My serial monitor was showing negative values for the sensor reading and it was in the 2000s. Then, I decided that I didn't really need different levels of brightness in the indicator anyway, what I really wanted was just a simple on/off LED effect (because I only really need those two values for the application of the sensor anyway). This is where I ran into my current problem.
PROBLEM
While attempting to code a Capacitive Proximity Sensor to trigger an LED on/off, I received the following error code.
In function 'void loop()':
CapSense-LED:24: error: 'lightState' was not declared in this scope
   lightState = digitalRead(sensorPin);        //returns high or low value from sensor
exit status 1
MY CODE
I'm pretty sure I've declared it. I've also tried moving it to void setup & changing it into a global variable, but when I changed it to global variable... it gave me an error code saying that I didn't declare a "type".
#include <CapacitiveSensor.h>
   CapitiveSense Library Demo Sketch
   Paul Badger 2008
   Uses a high value resistor e.g. 10M between send pin and receive pin
   Resistor effects sensitivity, experiment with values, 50K - 50M. Larger resistor values yield larger sensor values.
   Receive pin is the sensor pin - try different amounts of foil/metal on this pin
const int ledPin = 9;
const int sensorPin = 2;      //the pin that reads the capSensor value as Hight or Low
CapacitiveSensor   cs_2_4 = CapacitiveSensor(2, 4);       // 10M resistor between pins 2 & 4, pin 4 is sensor pin, add a wire and or foil if desired
//int lightLevel, high = 0, low = 1023;
  //cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
  pinMode(ledPin, OUTPUT);       //sets LED pinMode
  pinMode(sensorPin, INPUT);     //sets sensor pinMode
  digitalWrite(ledPin, lightState);       //writes a high or low value for LED light
  long start = millis();
  long total1 =  cs_2_4.capacitiveSensor(30);
  //long total2 =  cs_4_6.capacitiveSensor(30);
  //long total3 =  cs_4_8.capacitiveSensor(30);
  Serial.print(millis() - start);        // check on performance in milliseconds
  Serial.println("\t");                    // tab character for debug windown spacing
  Serial.print(total1);                  // print sensor output 1
  Serial.print("\t");
  Serial.print(lightState);
  delay(700);                             // arbitrary delay to limit data to serial port
  //mapping();          //mapping values of capSense for analog LED
/*void mapping() {
  //lightLevel = map(lightLevel, 0, 500, 0, 255);
  //lightLevel = constrain(lightLevel, 0, 255);
  if (lightLevel < low) {
    low = lightLevel;
  if (lightLevel > high) {
    high = lightLevel;
  lightLevel = map(lightLevel, low+30, high-30, 0, 255);
Please help and thanks in advance!
(Also, sorry if this is lengthy, I wanted to be as thorough as possible.)
P.S. I'm attaching a pic of my board in case that matters at all or if you have any additional tips. (Note: I had to connect five 10K resistors together because I didn't have any larger resistors. I don't know if the LED resistor/connection could potentially affect the rest of the circuit or not.)
CsGetDegrees:
In the code you posted you haven't...
saximus:
Sorry, I based it off a code from a previous tutorial I did yesterday that came from the Guidebook with the kit. So that was the only reason I said that. I must've misunderstood the code. Looking back now, I see that the tutorial declared the variable in the setup as an integer and that's what I missed.
I guess my actual problem now is:
What type of variable would I declare "lightState" as? Would it still be an integer if it's receiving a HIGH/LOW value?
I tried checking the reference on here but I couldn't figure out which one it would be.
If it's being used in the loop(), it needs to be declared as a global or in loop().
If you look up digitalRead(), it returns an int. If you're following good coding practice that means you should make lightState the same.
