I am renaming this thread because the subject line was previously wrong. Apologies but I do need advice.
After combining code I obtained through this forum concerning Dallas sensors, I got the following error report.
Arduino: 1.8.1 (Windows 7), Board: "Arduino Nano, ATmega328"
C:\Users\Ado\All Saves\Arduino\Saves\libraries\LiquidCrystal_I2C\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
#include <../Wire/Wire.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
I do not have the indicated line of code - ‘#include <…/Wire/Wire.h>’ anywhere in the sketch, could it be the library?
Interestingly the same error occurs with all my earlier saves and they were fault free when saved but the code I received from Nick_Pyner doesn’t suffer the same error.
I can send a verbose report but it takes four separate posts.
If you have an 8 megabyte output file, you have more problems than we can help with.
If you have something smaller than that, use Reply (NOT the Quick Reply field) and attach it using the Additional Options link that looks nothing like a link.
But, the error messages tells you the file that is causing the problem and the line number in that file.
I'm guessing that you are using a Mac, though, there they "help" you by hiding all that "crap". If you are, I can't help you. Haven't even opened my Mac in months. Not sure I even remember my password.
That library was written with the foolish assumption that the Wire library would always be in a specific location in relation to the LiquidCrystal_I2C library, which has caused no end of troubles over the years.
