Error response
I am working with an Arduino Due connected to a DWM1001 development board using UART connection.
To communicate with the board it must first be put into shell mode. This is done by sending two carriage returns (\r) within 1 second.
I have recently been having problems getting it into shell mode and I am not sure why. My first question is can anyone see something wrong with my code?
  Serial1.begin(115200);
  //Put DWM1001 dev into shell mode by sending two \r within one second
  Serial1.write('\r');
  delay(100);
  //Print response
  while (Serial1.available()) {
    Serial.println(Serial1.readStringUntil('\r'));
    delay(3000);
This code used to work, and very occasionally it will jump into shell mode and work. However, most of the time i just get "@ SOH SOH" as the response (means the board is not in shell mode).
Second question is about a random response I got one day. A photo is attached.
Has anyone seen this before? Is it an Arduino response or a response from the DWM1001 dev? I am not able to find any mention of this in any documentation for either the Arduino or the DWM1001.
Many thanks,
Macgregor
I'm going to make a guess... The DWM1001 didn't like being repeatedly asked to go into shell mode every 3 seconds (why are you doing that?), and crashed. You are seeing the DWM1001 firmware error diagnosic messages. I think your simplistic program just doesn't talk to the DWM1001 correctly. You should examine the RPI examples to see how it's done.
